    M5Paper blank display
    13 Posts 4 Posters 20.4k Views
      Powersoft
      When I load an example from the Arduino IDE "HelloWorld" the screen is staying blank. Some other also.
      Is there a solution of this problem?
      Thanks for any help.
      Jan
      • ZontexZ Offline
        Zontex @Powersoft
        @Powersoft Hi, do you get any error during the upload or the upload successfully complete?
          Powersoft @Zontex
          @zontex yes,the upload is okee. I found also when I chanhe the font the output is not working. By the way all examples in the ide ore not working wich are manipulating the canvas.
          • ZontexZ Offline
            Zontex
            @powersoft said in M5Paper blank display:
            Could you please try to burn the factory_test from the m5stack burner and see if the screen can react?
            P 2 Replies Last reply Reply Quote 0
              Powersoft @Zontex
              @zontex
              That's working fine! Tried this several times with succes!
              When compiling the examples I use the board "M5Stack-Fire".
              When I try to run the example "M5EPD_TTF" then it is not workin, blank screen. Have you tried this example found in the example directory?
              The SHT30 example is working fine.
              All thing related to the canvas like fonts, drawing etc gives the problem.
              Do you have could run all example files?
                Powersoft @Zontex
                @zontex
                Have running all demo programs
                Here the results:
                Button: failed
                DISPLAY_URL_JPG: failed
                HELLOWORLD: pass
                M5EPD_TTF: failed
                RTC_BM8563: pass
                SHT30: pass
                TOUCH: failed
                This is very strange!
                • ZontexZ Offline
                  Zontex @Powersoft
                  @powersoft Will try to re-produce and will let you know the results ASAP.
                    Powersoft @Zontex
                    @zontex
                    I appreciate that
                      Powersoft @Powersoft
                      @powersoft
                      Is there progress on this topic?
                        @powersoft
                        Found the solution. After setting into the preference the right url and loading the m5stack I was able to choose the M5Paper. Examples are running now👍
                        JopJ 1 Reply Last reply Reply Quote 0
                        • JopJ Offline
                          Jop @Powersoft
                          @powersoft
                          I met the same problems with my new M5Paper.
                          Please, can you be a bit more specific with "After setting into the preference the right url..."
                          I my boards I see different M5-products but not the M5Paper. Will this change by your solution?
                          Kind regards,
                          Jop
                          • m5stackM Online
                            m5stack @Jop
                            @jop after change the board manager URL, did you reinstall the board? (update to the latest version.)
                            check this tutorial:
                            https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino
                            board manager URL:
                            • JopJ Offline
                              Jop @m5stack
                              @m5stack thnx, I solved this problem - indeed I had to load board definitions
                              Also this YT-video 'M5Paper Seasons Greetings Display' was helpful: https://youtu.be/Tjz4fGRn8fo
                              Kind regards,
                              Jop
