<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Paper blank display]]></title><description><![CDATA[<p dir="auto">Hello,<br />
When I load an example from the Arduino IDE "HelloWorld" the screen is staying blank. Some other also.<br />
Is there a solution of this problem?</p>
<p dir="auto">Thanks for any help.</p>
<p dir="auto">Jan</p>
]]></description><link>https://community.m5stack.com/topic/2670/m5paper-blank-display</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 11:11:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2670.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Dec 2020 15:02:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Paper blank display on Sun, 21 Mar 2021 08:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1">@m5stack</a> thnx, I solved this problem - indeed I had to load board definitions</p>
<p dir="auto">Also this YT-video 'M5Paper Seasons Greetings Display' was helpful:  <a href="https://youtu.be/Tjz4fGRn8fo" target="_blank" rel="noopener noreferrer nofollow ugc">https://youtu.be/Tjz4fGRn8fo</a></p>
]]></description><link>https://community.m5stack.com/post/13167</link><guid isPermaLink="true">https://community.m5stack.com/post/13167</guid><dc:creator><![CDATA[Jop]]></dc:creator><pubDate>Sun, 21 Mar 2021 08:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Fri, 19 Mar 2021 04:17:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/7975">@jop</a>  after change the board manager URL, did you reinstall the board?  (update to the latest version.)</p>
<p dir="auto">check this tutorial:<br />
<a href="https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.m5stack.com/#/en/quick_start/m5paper/quick_start_arduino</a></p>
<p dir="auto">board manager URL:<br />
]]></description><link>https://community.m5stack.com/post/13122</link><guid isPermaLink="true">https://community.m5stack.com/post/13122</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Fri, 19 Mar 2021 04:17:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Thu, 18 Mar 2021 18:38:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a> said in <a href="/post/11618">M5Paper blank display</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a><br />
Found the solution. After setting into the preference the right url and loading the m5stack I was able to choose the M5Paper. Examples are running now👍</p>
<p dir="auto">I met the same problems with my new M5Paper.<br />
Please, can you be a bit more specific with "After setting into the preference the right url..."</p>
<p dir="auto">I my boards I see different M5-products but not the M5Paper. Will this change by your solution?</p>
]]></description><link>https://community.m5stack.com/post/13107</link><guid isPermaLink="true">https://community.m5stack.com/post/13107</guid><dc:creator><![CDATA[Jop]]></dc:creator><pubDate>Thu, 18 Mar 2021 18:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Fri, 08 Jan 2021 17:46:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a><br />
]]></description><link>https://community.m5stack.com/post/11618</link><guid isPermaLink="true">https://community.m5stack.com/post/11618</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Fri, 08 Jan 2021 17:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Fri, 01 Jan 2021 07:56:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a></p>
<p dir="auto">Is there progress on this topic?</p>
]]></description><link>https://community.m5stack.com/post/11485</link><guid isPermaLink="true">https://community.m5stack.com/post/11485</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Fri, 01 Jan 2021 07:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Thu, 31 Dec 2020 06:21:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4974">@zontex</a></p>
<p dir="auto">I appreciate that</p>
]]></description><link>https://community.m5stack.com/post/11463</link><guid isPermaLink="true">https://community.m5stack.com/post/11463</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Thu, 31 Dec 2020 06:21:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Thu, 31 Dec 2020 02:23:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a> Will try to re-produce and will let you know the results ASAP.</p>
]]></description><link>https://community.m5stack.com/post/11461</link><guid isPermaLink="true">https://community.m5stack.com/post/11461</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Thu, 31 Dec 2020 02:23:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Wed, 30 Dec 2020 16:05:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4974">@zontex</a><br />
Have running all demo programs<br />
Here the results:</p>
<p dir="auto">Button:	failed<br />
DISPLAY_URL_JPG:	failed<br />
HELLOWORLD:	pass<br />
M5EPD_TTF:	failed<br />
RTC_BM8563:	pass<br />
SHT30:	pass<br />
TOUCH:	failed</p>
<p dir="auto">This is very strange!</p>
]]></description><link>https://community.m5stack.com/post/11443</link><guid isPermaLink="true">https://community.m5stack.com/post/11443</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Wed, 30 Dec 2020 16:05:56 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Wed, 30 Dec 2020 14:06:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4974">@zontex</a><br />
That's working fine! Tried this several times with succes!<br />
When compiling the examples I use the board "M5Stack-Fire".</p>
<p dir="auto">When I try to run the example "M5EPD_TTF" then it is not workin, blank screen. Have you tried this example found in the example directory?<br />
The SHT30 example is working fine.</p>
<p dir="auto">All thing related to the canvas like fonts, drawing etc gives the problem.</p>
<p dir="auto">Do you have could run all example files?</p>
]]></description><link>https://community.m5stack.com/post/11442</link><guid isPermaLink="true">https://community.m5stack.com/post/11442</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Wed, 30 Dec 2020 14:06:59 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Wed, 30 Dec 2020 10:02:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@powersoft</a> said in <a href="/post/11434">M5Paper blank display</a>:</p>
<p dir="auto">e upload is okee. I found also when I chanhe the font the output is not working. By the way all examples in the ide ore not working wich are manipulating the canvas.</p>
<p dir="auto">Could you please try to burn the factory_test from the m5stack burner and see if the screen can react?</p>
]]></description><link>https://community.m5stack.com/post/11438</link><guid isPermaLink="true">https://community.m5stack.com/post/11438</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Wed, 30 Dec 2020 10:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Wed, 30 Dec 2020 09:28:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/4974">@zontex</a> yes,the upload is okee. I found also when I chanhe the font the output is not working. By the way all examples in the ide ore not working wich are manipulating the canvas.</p>
]]></description><link>https://community.m5stack.com/post/11434</link><guid isPermaLink="true">https://community.m5stack.com/post/11434</guid><dc:creator><![CDATA[Powersoft]]></dc:creator><pubDate>Wed, 30 Dec 2020 09:28:45 GMT</pubDate></item><item><title><![CDATA[Reply to M5Paper blank display on Wed, 30 Dec 2020 08:43:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1718">@Powersoft</a> Hi, do you get any error during the upload or the upload successfully complete?</p>
]]></description><link>https://community.m5stack.com/post/11433</link><guid isPermaLink="true">https://community.m5stack.com/post/11433</guid><dc:creator><![CDATA[Zontex]]></dc:creator><pubDate>Wed, 30 Dec 2020 08:43:47 GMT</pubDate></item></channel></rss>
