    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 149.6k Views 2 Watching
      Richard
      i have install PlatformIO and load my projet:
      Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
      Hash of data verified.
      Leaving...
      Hard resetting via RTS pin...
      ====================================================== [SUCCESS] Took 23.68 seconds =======================================
      I still have the problem!
      hardware problem?
      I
        Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
          Calin @Richard
          @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
          I use Visual Studio, Eclipse or PlatformIO.
          I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
          The M5Stack library is already installed local into project.
          All you have to do is to download the repository and compile the code.
            ajb2k3 @Calin
            @calin 在 drawJpgFile / drawBmpFile 中说:
            Maybe a stupid question (or two) but I'm going to ask anyway.
            Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
            Is there a specific image limitation for the image?
              Richard
              I use Visual Studio too.
              i have just tested your programm and i still have the problem.
              I think it's a hardware problem.
              I'm waiting for another device
              Thank you.
                Calin @Richard
                @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                I think there is no limitation on card size.
                There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                As i know, the cards formatted as FAT32 are preffered.
                @richard 在 drawJpgFile / drawBmpFile 中说:
                Thank you.
                That problem can be caused by the ILI9341 controller from the TFT.
                If that is the case, the only solution is a replacement.
                  Richard
                  I use a SD 4mo FAT32
                    Richard
                    and also
                    I tested with a 32mo
                      I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                      How do I tell if I have the ILI9341?
                        Calin @ajb2k3
                        @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                          Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                          I had to reduce the image to a 256bit Indexed image!
                            Richard
                            I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                            It works very well.
                            The first M5stack doesn't work propely.
                            I hope the M5stack store will change it.
                              Richard
                                Richard
                                Thank you Calin!
