    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 146.6k Views 2 Watching
      Calin
      Please share your code so i can check and see what's the problem there.
        Richard
        my code
        #include <M5Stack.h>
        void setup(void) {
        M5.Lcd.setBrightness(200);
        M5.Lcd.drawJpgFile(SD, "/corto.jpg"); // Load background from SD
        //M5.Lcd.drawJpgFile(SD, "/corto_1.jpg", 0, 20, 300, 200);
        // M5.Lcd.drawJpgFile(fs::FS &fs, const char *path, uint16_t x, uint16_t y, uint16_t maxWidth, uint16_t maxHeight, uint16_t offX, uint16_t offY, jpeg_div_t scale);
        M5.update();
        delay(1000);
        Thank you
          Richard
            Richard
            m5stack from m5stack store
              Richard
                Calin
                Here is the test using your code (with small modifications and relevant comments)
                and standard m5Stack library from PlatformIO:
                And here is the result:
                  Richard
                  fine, but does not work on ide arduino.
                  can you send me your code in espi setup?
                    Richard
                    do you have tested my with arduino ide?
                    thank you
                      Richard
                      i have install PlatformIO and load my projet:
                      Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                      Hash of data verified.
                      Leaving...
                      Hard resetting via RTS pin...
                      ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                      I still have the problem!
                      hardware problem?
                      I
                        Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                          Calin @Richard
                          @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                          I use Visual Studio, Eclipse or PlatformIO.
                          I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                          The M5Stack library is already installed local into project.
                          All you have to do is to download the repository and compile the code.
                            ajb2k3 @Calin
                            @calin 在 drawJpgFile / drawBmpFile 中说:
                            Maybe a stupid question (or two) but I'm going to ask anyway.
                            Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                            Is there a specific image limitation for the image?
                              Richard
                              I use Visual Studio too.
                              i have just tested your programm and i still have the problem.
                              I think it's a hardware problem.
                              I'm waiting for another device
                              Thank you.
                                Calin @Richard
                                @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                                I think there is no limitation on card size.
                                There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                                As i know, the cards formatted as FAT32 are preffered.
                                @richard 在 drawJpgFile / drawBmpFile 中说:
                                Thank you.
                                That problem can be caused by the ILI9341 controller from the TFT.
                                If that is the case, the only solution is a replacement.
                                  Richard
                                  I use a SD 4mo FAT32
                                    Richard
                                    and also
                                    I tested with a 32mo
                                      I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                                      How do I tell if I have the ILI9341?
                                        Calin @ajb2k3
                                        @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                                          Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                                          I had to reduce the image to a 256bit Indexed image!
                                            Richard
                                            I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                                            It works very well.
                                            The first M5stack doesn't work propely.
                                            I hope the M5stack store will change it.
