    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 144.1k Views 2 Watching
      ajb2k3 @Calin
      @calin 在 drawJpgFile / drawBmpFile 中说:
      @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
      I use Visual Studio, Eclipse or PlatformIO.
      I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
      The M5Stack library is already installed local into project.
      All you have to do is to download the repository and compile the code.
      Maybe a stupid question (or two) but I'm going to ask anyway.
      Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
      Is there a specific image limitation for the image?
        Richard
        I use Visual Studio too.
        i have just tested your programm and i still have the problem.
        I think it's a hardware problem.
        I'm waiting for another device
        Thank you.
          Calin @Richard
          @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
          I think there is no limitation on card size.
          There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
          As i know, the cards formatted as FAT32 are preffered.
          @richard 在 drawJpgFile / drawBmpFile 中说:
          Thank you.
          That problem can be caused by the ILI9341 controller from the TFT.
          If that is the case, the only solution is a replacement.
            Richard
            I use a SD 4mo FAT32
              Richard
              and also
              I tested with a 32mo
                I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                How do I tell if I have the ILI9341?
                  Calin @ajb2k3
                  @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
                    Ok, failed to get it to work with the jpgdraw script but if I convert to array it works, But!!!!!!
                    I had to reduce the image to a 256bit Indexed image!
                      Richard
                      I tested my programm and my file jpg (sd 4go) with IDE Arduino 1.8.5 on another M5Stack .
                      It works very well.
                      The first M5stack doesn't work propely.
                      I hope the M5stack store will change it.
                        Richard
                          Richard
                          Thank you Calin!
