    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 149.6k Views 2 Watching
      Calin @Richard
      @richard The TFT SPI frequency is defined on In_eSPI_Setup.h file from M5Stack library at line 202: https://github.com/m5stack/M5Stack/blob/1772fd68743a7728e64ab6d24b931e1183599981/src/utility/In_eSPI_Setup.h#L202
      Try to set it to 27000000
      The SD SPI freqency can be different than TFT SPI frequency, since SD is on a different SPI bus.
        Richard @Calin
        @calin
        thanks,
        I tried but I still have the problem!
        no idea
          Calin
          Please share your code so i can check and see what's the problem there.
            Richard
            my code
            #include <M5Stack.h>
            void setup(void) {
            M5.Lcd.setBrightness(200);
            M5.Lcd.drawJpgFile(SD, "/corto.jpg"); // Load background from SD
            //M5.Lcd.drawJpgFile(SD, "/corto_1.jpg", 0, 20, 300, 200);
            // M5.Lcd.drawJpgFile(fs::FS &fs, const char *path, uint16_t x, uint16_t y, uint16_t maxWidth, uint16_t maxHeight, uint16_t offX, uint16_t offY, jpeg_div_t scale);
            M5.update();
            delay(1000);
            Thank you
              Richard
                Richard
                m5stack from m5stack store
                  Richard
                    Calin
                    Here is the test using your code (with small modifications and relevant comments)
                    and standard m5Stack library from PlatformIO:
                    And here is the result:
                      Richard
                      fine, but does not work on ide arduino.
                      can you send me your code in espi setup?
                        Richard
                        do you have tested my with arduino ide?
                        thank you
                          Richard
                          i have install PlatformIO and load my projet:
                          Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                          Hash of data verified.
                          Leaving...
                          Hard resetting via RTS pin...
                          ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                          hardware problem?
                          I
                            Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                              Calin @Richard
                              @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                              I use Visual Studio, Eclipse or PlatformIO.
                              I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                              The M5Stack library is already installed local into project.
                              All you have to do is to download the repository and compile the code.
                                ajb2k3 @Calin
                                @calin 在 drawJpgFile / drawBmpFile 中说:
                                Maybe a stupid question (or two) but I'm going to ask anyway.
                                Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                                Is there a specific image limitation for the image?
                                  Richard
                                  I use Visual Studio too.
                                  i have just tested your programm and i still have the problem.
                                  I think it's a hardware problem.
                                  I'm waiting for another device
                                  Thank you.
                                    Calin @Richard
                                    @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                                    I think there is no limitation on card size.
                                    There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                                    As i know, the cards formatted as FAT32 are preffered.
                                    @richard 在 drawJpgFile / drawBmpFile 中说:
                                    Thank you.
                                    That problem can be caused by the ILI9341 controller from the TFT.
                                    If that is the case, the only solution is a replacement.
                                      Richard
                                      I use a SD 4mo FAT32
                                        Richard
                                        and also
                                        I tested with a 32mo
                                          I have a 32gig Class 10 sdhc formatted as fat32 MBT.
                                          How do I tell if I have the ILI9341?
                                            Calin @ajb2k3
                                            @ajb2k3 ILI9341 is the LCD driver used by the M5Stack TFT display: https://cdn-shop.adafruit.com/datasheets/ILI9341.pdf
