    drawJpgFile / drawBmpFile
    30 Posts 4 Posters 149.6k Views 2 Watching
      Richard
      thanks, but I don't find this driver
        Richard @Richard
        @richard
        I tried all the tft spi sd frequencies and I still have the problem!
        an idea?
          Calin @Richard
          @richard The TFT SPI frequency is defined on In_eSPI_Setup.h file from M5Stack library at line 202: https://github.com/m5stack/M5Stack/blob/1772fd68743a7728e64ab6d24b931e1183599981/src/utility/In_eSPI_Setup.h#L202
          Try to set it to 27000000
          The SD SPI freqency can be different than TFT SPI frequency, since SD is on a different SPI bus.
            Richard @Calin
            @calin
            thanks,
            I tried but I still have the problem!
            no idea
              Calin
              Please share your code so i can check and see what's the problem there.
                Richard
                my code
                #include <M5Stack.h>
                void setup(void) {
                M5.Lcd.setBrightness(200);
                M5.Lcd.drawJpgFile(SD, "/corto.jpg"); // Load background from SD
                //M5.Lcd.drawJpgFile(SD, "/corto_1.jpg", 0, 20, 300, 200);
                // M5.Lcd.drawJpgFile(fs::FS &fs, const char *path, uint16_t x, uint16_t y, uint16_t maxWidth, uint16_t maxHeight, uint16_t offX, uint16_t offY, jpeg_div_t scale);
                M5.update();
                delay(1000);
                Thank you
                  Richard
                    Richard
                    m5stack from m5stack store
                      Richard
                        Calin
                        Here is the test using your code (with small modifications and relevant comments)
                        and standard m5Stack library from PlatformIO:
                        And here is the result:
                          Richard
                          fine, but does not work on ide arduino.
                          can you send me your code in espi setup?
                            Richard
                            do you have tested my with arduino ide?
                            thank you
                              Richard
                              i have install PlatformIO and load my projet:
                              Wrote 230992 bytes (123957 compressed) at 0x00010000 in 11.0 seconds (effective 168.6 kbit/s)...
                              Hash of data verified.
                              Leaving...
                              Hard resetting via RTS pin...
                              ====================================================== [SUCCESS] Took 23.68 seconds =======================================
                              hardware problem?
                              I
                                Agreed, Following this myself and just get a blank screen with the image not loaded. This is my image 0_1529644400361_logo.jpg
                                  Calin @Richard
                                  @richard No. i didn't tested with arduino "ide". I uninstalled that from my PC because is mostly useless...
                                  I use Visual Studio, Eclipse or PlatformIO.
                                  I uploaded the PlatformIO project for your code to github: https://github.com/botofancalin/M5StackJpgtest
                                  The M5Stack library is already installed local into project.
                                  All you have to do is to download the repository and compile the code.
                                    ajb2k3 @Calin
                                    @calin 在 drawJpgFile / drawBmpFile 中说:
                                    Maybe a stupid question (or two) but I'm going to ask anyway.
                                    Is there a hardware limitation for this i.e. is there a card size limit and a formatting requirement?
                                    Is there a specific image limitation for the image?
                                      Richard
                                      I use Visual Studio too.
                                      i have just tested your programm and i still have the problem.
                                      I think it's a hardware problem.
                                      I'm waiting for another device
                                      Thank you.
                                        Calin @Richard
                                        @ajb2k3 在 drawJpgFile / drawBmpFile 中说:
                                        I think there is no limitation on card size.
                                        There might be a limitation on card read/write speed and that depend on the sdcard manufacturer and model.
                                        As i know, the cards formatted as FAT32 are preffered.
                                        @richard 在 drawJpgFile / drawBmpFile 中说:
                                        Thank you.
                                        That problem can be caused by the ILI9341 controller from the TFT.
                                        If that is the case, the only solution is a replacement.
                                          Richard
                                          I use a SD 4mo FAT32
                                            Richard
                                            and also
                                            I tested with a 32mo
