A
Connect the QMP6 to the hub and the hub gives it a different virtual address. Address are often set at the hardware level and can sometimes be changes by changing the solder points on the PCB of the sensor.
F
Hello @gunnm
yes, that is my understanding from reading the datasheet. The I2C address can only be changed via hardware.
Thanks Felix
