hello everyone.
I hope you can help me. is it possible that arduino ide does not read me ffat scheme but only SPIFFS?
Is there any way to solve this problem?
I thank you for your help.
hello everyone.
hello everyone.
I need some help. I'm trying to run multiple units through a PaHub but I'm experiencing problems with the ENV3 sensor, specifically the pressure.
I realized that both the QMP6988 sensor and the PaHub use the same address, 0x70. Also, I read in the QMP6988 data sheet that it has two available addresses, the second of which is 0x56. I have tried every way to make QMP6988 communicate via address 0x56, but with no result always 0x70 uses. Can anyone help me please?
I thank you in advance.
Best regards Nicholas.
Hi all guys.
I will explain my problem right away. Through arduino I am trying to connect several sensors including the ENV3 to the PaHUB. But with the ENV3 I am experiencing a communication problem this is because QMP6988 and PaHUB communicate on the same address and this does not allow my M5Stickc Plus to receive the pressure value. Is there any way to change the communication address of the QMP6988?
Thank you in advance,
Sincerely
Nicholas.
