Subcategories
  • 5 Topics
    H
    thank you so much for sharing! this looks cool. I am pretty new to micropython for M5Stack. May I ask which IDE you primarily use to do Micropython programming?
  • Arduino IDE 2.3.9 Debugging [sharing]
  • M5PaperColor: Can't read both SHT40 and battery data?
    felmueF
    Hello @Shipbrook M5Unified uses Wire1 for internal I2C and Wire for external I2C. The example for SHT40 incorrectly uses Wire which causes issues as soon as other internal I2C communication is required, e.g. reading battery status. The quick way to fix this is replacing Wire with Wire1 in below line: //if(!sht4.begin(&Wire, SHT40_I2C_ADDR_44, SHT_SDA_PIN, SHT_SCL_PIN, 400000U)) if(!sht4.begin(&Wire1, SHT40_I2C_ADDR_44, SHT_SDA_PIN, SHT_SCL_PIN, 400000U)) The better way is to get the actual port used by M5Unified for internal I2C and the use that information: i2c_port_t PortIn = M5.In_I2C.getPort(); TwoWire * WireIn = (PortIn == 1) ? &Wire1 : &Wire; if(!sht4.begin(WireIn, SHT40_I2C_ADDR_44, SHT_SDA_PIN, SHT_SCL_PIN, 400000U)) Thanks Felix
  • Unit Roller485 - ease in out in position mode?
  • M5Dial Example App - Home Assistant, RSS News and OpenWeatherMap
    P
    [image: 1772814000502-7e5ce5b2-8d9d-48f9-ae34-7fa5884c1e12-image.png]
  • Tab5 I2C on Arduino works, same code does not work on PlatformIO
    1 Votes
    1k Views
    T
    Update on this one: Changing to other pins for external I2C makes it work for both Arduino and PlatformIO. So with arduino you can lay external I2C over the internal I2C, but in PlatformIO that does not work. Anybody an idea why not?
  • M5Stack Core/Basic board management package mirror
  • M5Stack CoreS3 SE + COMMU display problem when replugging USB
    F
    it was caused by the CS of the LAN Module13.2. switching the jumper to the alternate position fixed the problem... so far these seem to work (CoreS3 SE+COMMU+Lan Module13.2+DIN Base): int cs_pin = 13; // jumper right int rst_pin = 0; // jumper left int int_pin = 10;// jumper left
  • Problems with M5GFX Library
    1 Votes
    V
    @007jimmey Any update or resolution? Im encountering this on ArduinoDroid...
  • Scan using M5 Unified for IC2 devices for a M5Dial fails
    felmueF
    Hello @VashJuan well, it looks to me that none of the listed devices are actually I2C devices. Grove Temp. Sensor: has an analog out pin (the other is NC) which means it directly sends an analog value Grove Wireless Mod: has RX and TX which means it has an UART interface Buzzer: well, my guess would be that it is not I2C either Thanks Felix
  • Tab5 Display Power Save
    arduino
  • 0 Votes
  • esp32/rom/rtc.h No such file or directory
    1k Views
    S
    @scroggyg The file exists, could the path length be too long? C:\Users\xxxxxxxxxxxxxx\xxxxxxxxxxxxxx\Documents\Arduino\hardware\espressif\esp32\tools\sdk\esp32s3\include\esp_rom\include\esp32\rom
  • Display png from sd with tab5
    1k Views
  • Visual Code and M5StamPLC with new M5Unified
    G
    Hello, I've gotten a little closer to the problem. First, I performed a full clean in Visual Studio using platformio AND deactivated the entry for M5Unified. The new M5Unified@0.2.8 continued to load: Processing m5stampplc-test (platform: espressif32; board: esp32-s3-devkitc-1; framework: arduino) ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Library Manager: Installing git+https://github.com/m5stack/M5StamPLC git version 2.43.0 Cloning into '/Users/myname/.platformio/.cache/tmp/pkg-installing-pmi7_zhl'... remote: Enumerating objects: 70, done. remote: Counting objects: 100% (70/70), done. remote: Compressing objects: 100% (57/57), done. remote: Total 70 (delta 4), reused 29 (delta 1), pack-reused 0 (from 0) Receiving objects: 100% (70/70), 80.39 KiB | 2.77 MiB/s, done. Resolving deltas: 100% (4/4), done. Library Manager: M5StamPLC@1.0.0+sha.1021da5 has been installed! Library Manager: Resolving dependencies... Library Manager: Installing M5Unified @ * Unpacking [####################################] 100% Library Manager: M5Unified@0.2.8 has been installed! Library Manager: Resolving dependencies... Library Manager: Installing M5GFX @ >=0.2.10 Unpacking [####################################] 100% Library Manager: M5GFX@0.2.10 has been installed! A look at the library.json revealed the challenge in my opinion: dependencies to "M5Unified" - No specific version of M5Unified, always the latest! "name": "M5StamPLC", "description": "Library for M5StamPLC", "keywords": "M5Stack,M5StamPLC", "authors": { "name": "M5Stack" }, "repository": { "type": "git", "url": "https://github.com/M5Stack/M5StamPLC.git" }, "dependencies": { "M5Unified": "*", "M5GFX": "*" }, "version": "1.0.0", "frameworks": "arduino", "platforms": "espressif32" } Before I copy and adapt everything locally, it would certainly be helpful to adapt this. In my opinion, there must be an M5StamPLC version 1.0.1 with the new features, and the old version M5StamPLC 1.0.0 must use M5Unified version 0.2.7. Who (from M5Stack) can help me?
  • M5TAB5
    felmueF
    Hello @Powersoft please have a look at my M5Tab5 library (unofficial) here. Thanks Felix
  • ESP-Now-Serial-Bridge on M5Atom S3
    1k Views
  • M5StamPLC can't connect in Arduino IDE
    T
    I solved it. My usb c cable was junk.
    G
    Hello @felmue, yes, I did, but I didn't see this part: [env:m5stack-stamp-s3] platform = espressif32 board = esp32-s3-devkitc-1 framework = arduino upload_speed = 1500000 build_flags = -DESP32S3 -DCORE_DEBUG_LEVEL=5 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MODE=1 lib_deps = M5StamPLC=https://github.com/m5stack/M5StamPLC M5Unified=https://github.com/m5stack/M5Unified Thanks, I will try it.
  • I2c failure with MPU6050 component
    arduino
    G
    More information If I use M5Unified.h and then a begin of M5.begin(), the data is all zeros. If I take out the begin, then the data is correct. There must be something in the M5Unified that is restarting the Wire or taking over the I2C bus. How can I correct this. It is a show stopper. If I can find a solution, then I will have to discard the M5Stack basic and go to a regular ESP32.
  • M5StamPLC and the Backlight
    3k Views
    G
    Hello @felmue, thank you very much for your quick support, it really helped me. It didn't work in my "big" program, but I wrote a small test program, and it fully meets the requirements: #include <M5StamPLC.h> void my_set_backlight(bool o) { PI4IOE5V6408_Class p; p.setDirection(7, true); // false input, true output p.digitalWrite(7, !o); // false on, true off } void printAndWait(String s) { M5StamPLC.Display.println(" " + s); delay(4000); } void setup() { Serial.begin(115200); M5StamPLC.begin(); M5StamPLC.Display.setTextSize(3); } void loop() { M5StamPLC.Display.fillScreen(TFT_BLACK); M5StamPLC.Display.setCursor(0, 10); printAndWait("Test 1"); printAndWait("Test 2"); my_set_backlight(false); printAndWait("Test 3"); my_set_backlight(true); printAndWait("Test 4"); } You can see it not only in the dark screen, but also in the power consumption, which is reduced by about 20%. I suspect that in my "big" program, someone is turning the lights back on (and working against me). Best regards, Uwe
