@kuriko Thanks. How can I do it?
Posts made by l.roca
Unit CamS3 and MicroPythonposted in Units
Hi,
I wish to program Unit CamS3 using MicroPython but when I flash them using this:
I ge this shell message in Thonny even before I start to program:
PROBLEM IN THONNY'S BACK-END: Internal error (serial.serialutil.SerialTimeoutException: Write timeout).
See Thonny's backend.log for more info.
You may need to press "Stop/Restart" or hard-reset your MicroPython device and try again.Process ended with exit code 0.
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
As "Stop/Restart" cycles does not solve, any idea how to solve it? and to start programming?
TimerCamera-X and MicroPythonposted in Units
Hi,
I wish to program TimerCamera-X using MicroPython but when I flash them using this:
I get this shell message in Thonny even before I start to program:
Device is busy or does not respond. Your options:
- wait until it completes current work;
- use Ctrl+C to interrupt current work;
- reset the device and try again;
- check connection properties;
- make sure the device has suitable MicroPython / CircuitPython / firmware;
- make sure the device is not in bootloader mode.
ets Jul 29 2019 12:21:46
rst:0x5 (DEEPSLEEP_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
οΏ½
|_ ()_ __ ___ ___ _ __ / | _ _ __ ___
| | | | '_ \ / _ \ '__| | / _| '_ ` _ \
|| ||| || ||_|| __,|| || |_|Reading config info...
-- Wifi SSID: LAQ980
-- Wake time: 30
-- Image size: 5
Camera init...
Camera Init Success
Starting post server
Wifi init...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
Connecting...
got ip:X.X.X.X (Hidden by my)
SuccessCapturing image...
Posting image to server...success!
-- Image posted to url: http://api.m5stack.com:5003/timer-cam/image?tok=
-- Please add your token at the end of the url
-- You can get your token in M5BurnerTimerCam will be wake up after 30 seconds
Power off :)It will run in a loop. Any idea how to solve it? And to start programming?
RE: Unexpected results when using intensity slider for LED vontrolposted in UiFlow 2.0
@robski If I set them manually in the GreenSwitch and whiteSwitch it works fine
Regarding previous posts about the green LED control: Iβve implemented an intensity slider, but itβs behaving unexpectedly. The light shifts to red instead of dimming the green. Interestingly, the color is correct when brightness is set manually to 100%. Does anyone have insight into what might be the reason?
Industrial Analog pH Meterposted in Features Wish List
Hi,
A good industrial pH Meter Kit will be great to have.
Thanks
RE: MOSFET unitposted in Features Wish List
@teastain can you please share the scheme how to built a MOSFET inside a M5Stack Proto Unit. Thanks
Unit CamS3 Wi-Fi Camera 5MP store images on cloudposted in Units
Hi,
Is there a way to store the Unit CamS3 Wi-Fi Camera 5MP images taken in intervals in different filenames directly to at a cloud service (e.g. google drive, one drive)?
Thanks
RE: GROVE2GROVE and 5V DC fanposted in Units
@teastain @felmue Thanks a lot. One further question: do I always have to give 5V via external power source?
@teastain Arduino code will also be fine ;-). How do I connect the fan to the unit?
Hi,
Following this post , how do I connect a 5V DC to the Grove2Grove unit?
A simple scheme will be very helpful (as I am a newbie)
Can it get the power directly from the Grove? Or I need external power supply?Thanks
