    TimerCamera-X and MicroPython
    3 Posts 2 Posters 258 Views
    • L Offline
      l.roca
      I wish to program TimerCamera-X using MicroPython but when I flash them using this:
      I get this shell message in Thonny even before I start to program:
      Device is busy or does not respond. Your options:
      • wait until it completes current work;
      • use Ctrl+C to interrupt current work;
      • reset the device and try again;
      • check connection properties;
      • make sure the device has suitable MicroPython / CircuitPython / firmware;
      • make sure the device is not in bootloader mode.
      ets Jul 29 2019 12:21:46
      rst:0x5 (DEEPSLEEP_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:2
      load:0x3fff0018,len:4
      load:0x3fff001c,len:1044
      load:0x40078000,len:10124
      load:0x40080400,len:5828
      entry 0x400806a8
      |_ ()_ __ ___ ___ _ __ / | _ _ __ ___
      _ \ / _ \ '__| | / _ | '_ ` _ \
      | ||| || ||_|| __,|| || |_|
      Reading config info...
      -- Wifi SSID: LAQ980
      -- Wake time: 30
      -- Image size: 5
      Camera init...
      Camera Init Success
      Starting post server
      Wifi init...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      Connecting...
      got ip:X.X.X.X (Hidden by my)
      Success
      Capturing image...
      Posting image to server...success!
      -- Image posted to url: http://api.m5stack.com:5003/timer-cam/image?tok=
      -- Please add your token at the end of the url
      -- You can get your token in M5Burner
      TimerCam will be wake up after 30 seconds
      Power off :)
      It will run in a loop. Any idea how to solve it? And to start programming?
      • kurikoK Offline
        kuriko @l.roca
        @l-roca
        This is not a Micropython firmware. This firmware was used to post images through HTTPS to controllers which was programmed in UIFlow.
        L 1 Reply Last reply Reply Quote 1
        • L Offline
          l.roca @kuriko
          Thanks. How can I do it?
