    [Solved] M5 Burner Firmware Option Update
    SOFTWARE
    7
    69
    401.2k
    • G
      GACHAPO @m5-docs
      @watson Thank you.
      Do I choose CAMERA_MODEL_WROVER_KIT?
      m5-docsM 1 Reply Last reply Reply Quote 0
      • m5-docsM
        m5-docs @GACHAPO
        @gachapo
        You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
        // Select camera model
        //#define CAMERA_MODEL_WROVER_KIT
        #define CAMERA_A_MODEL_M5STACK_PSRAM
        //#define CAMERA_MODEL_AI_THINKER
        https://docs.m5stack.com/#/en/unit/esp32cam
        M5Stack documentation URL
        • m5-docsM
          m5-docs
          @GACHAPO @ajb2k3 Thanks your support
          G 1 Reply Last reply Reply Quote 1
          • G
            GACHAPO @m5-docs
            @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
            • m5-docsM
              m5-docs @GACHAPO
              @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
              https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
              #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
              #define PWDN_GPIO_NUM     -1
              #define RESET_GPIO_NUM    15
              #define XCLK_GPIO_NUM     27
              #define SIOD_GPIO_NUM     25
              #define SIOC_GPIO_NUM     23
              #define Y9_GPIO_NUM       19
              #define Y8_GPIO_NUM       36
              #define Y7_GPIO_NUM       18
              #define Y6_GPIO_NUM       39
              #define Y5_GPIO_NUM        5
              #define Y4_GPIO_NUM       34
              #define Y3_GPIO_NUM       35
              #define Y2_GPIO_NUM       32
              #define VSYNC_GPIO_NUM    22
              #define HREF_GPIO_NUM     26
              #define PCLK_GPIO_NUM     21
              • G
                GACHAPO
                Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                • m5-docsM
                  m5-docs @GACHAPO
                  @gachapo
                  https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram
                  • G
                    GACHAPO
                    Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                    • ajb2k3A
                      ajb2k3 @GACHAPO
                      @gachapo said in [Solved] M5 Burner Firmware Option Update:
                      No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                      Something I have failed to do several times now.
                      • m5-docsM
                        m5-docs
                        can also program with arduino ide
                        G 1 Reply Last reply Reply Quote 0
                        • G
                          GACHAPO @m5-docs
                          @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                          Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                          I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                          Compiles and uploaded the sketch.
                          Nothing! - Camera doesn't even turn on.
                          Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                          Thanks
                          O 1 Reply Last reply Reply Quote 0
                          • O
                            Oyye @GACHAPO
                            @gachapo
                            I just registered for you :D
                            Here what is solved my problem (Y2_GPIO_NUM):
                            #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                            #define Y2_GPIO_NUM 17 //32
                            ajb2k3A G 2 Replies Last reply Reply Quote 0
                            • ajb2k3A
                              ajb2k3 @Oyye
                              @oyye said in [Solved] M5 Burner Firmware Option Update:
                              @gachapo
                              Welcome to the forum!
                              • G
                                GACHAPO @Oyye
                                @oyye Thank-you,
                                I did as you stated with only change from the Arduino Examples being;
                                This has made no change - Camera still does not come on.
                                Just to be absolutely clear - this is the camera a have
                                ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                                • G
                                  GACHAPO
                                  Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
                                  • m5-docsM
                                    m5-docs @GACHAPO
                                    @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
                                    • G
                                      GACHAPO @m5-docs
                                      @m5-docs I own an M5 OV2640 ESP32PSRAM Camera
                                      • m5-docsM
                                        m5-docs @GACHAPO
                                        @gachapo But, M5Camera A model and B model both own PSRAM chip.
                                        Please take a picture for your camera board.
                                        https://docs.m5stack.com/#/en/unit/m5camera
                                        • G
                                          GACHAPO
                                          Mine is B
                                          • m5-docsM
                                            m5-docs @GACHAPO
                                            Hello @gachapo
                                            You can download the following example code for your board.
                                            That's the configuration for B Model.
                                            #define SIOD_GPIO_NUM     22
                                            #define VSYNC_GPIO_NUM    25
