    [Solved] M5 Burner Firmware Option Update
    SOFTWARE
    7
    69
    395.4k
    • G
      GACHAPO
      Hi,
      I've see that document and youtube video. I just need to know how to move the camera from M5stack AP connection on 192.168.4.1 to an assigned ip address by myself like 192.168.1.131?
      Thanks
      • ajb2k3A
        ajb2k3 @GACHAPO
        @gachapo you need to recompile the code is ST mode and upload to cameea
        G 1 Reply Last reply Reply Quote 0
        • G
          GACHAPO @ajb2k3
          @ajb2k3 Thanks - Is there any documentation you can point me to please?
          ajb2k3A m5-docsM 2 Replies Last reply Reply Quote 0
          • ajb2k3A
            ajb2k3 @GACHAPO
            @gachapo only the official espressiv and espcam docs
            • m5-docsM
              m5-docs @GACHAPO
              @gachapo At main.c file
              M5Stack documentation URL
              https://docs.m5stack.com
              • G
                GACHAPO
                Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
                m5-docsM 1 Reply Last reply Reply Quote 0
                • m5-docsM
                  m5-docs @GACHAPO
                  @gachapo
                  Download the firmware of ESP32CAM
                  https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram
                  • G
                    GACHAPO
                    ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
                    • ajb2k3A
                      ajb2k3 @m5-docs
                      @watson I can't use the M5burner of the Stick C as it it coming up as
                      Port: "dev/cu.serial-6D52F9B441
                      instead of the expected
                      Port: "dev/cu.SLAB_USBtoUART
                      • m5-docsM
                        m5-docs @ajb2k3
                        @ajb2k3 Are you working with Mac OS?
                        • ajb2k3A
                          ajb2k3 @m5-docs
                          @watson
                          Yes, but is only the StickC that is giving the strange port ID.
                          All others report normal port.
                          • m5-docsM
                            m5-docs @GACHAPO
                            @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                            • S
                              salty_good
                              I understood this problem.
                              We need to fix M5Burner for mac.
                              ajb2k3A 1 Reply Last reply Reply Quote 1
                              • ajb2k3A
                                ajb2k3 @salty_good
                                @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                                Can you add drop down box to select port?
                                ポートを選択するためのドロップダウンボックスを追加できますか?
                                S 1 Reply Last reply Reply Quote 0
                                • m5-docsM
                                  m5-docs @GACHAPO
                                  • S
                                    salty_good @ajb2k3
                                    @ajb2k3 Off course yes,
                                    and Baudrate also needs to be selectable.
                                    • G
                                      GACHAPO @m5-docs
                                      @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                                      • m5-docsM
                                        m5-docs @GACHAPO
                                        Hello @gachapo It's best to use esp-idf.
                                        • G
                                          GACHAPO @m5-docs
                                          @watson Thanks- can you use arduino-ide?
                                          • m5-docsM
                                            m5-docs @GACHAPO
                                            Hello @gachapo,
                                            Yes, Color recognition arduino program may help you.
                                            Here's the code:
                                            https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
