    69 Posts 7 Posters 442.4k Views 1 Watching
    • G Offline
      GACHAPO @m5-docs
      @watson Thanks- can you use arduino-ide?
      • m5-docsM Offline
        m5-docs @GACHAPO
        Hello @gachapo,
        Yes, Color recognition arduino program may help you.
        Here's the code:
        https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
        M5Stack documentation URL
        https://docs.m5stack.com
        • G Offline
          GACHAPO @m5-docs
          @watson Thank you.
          Do I choose CAMERA_MODEL_WROVER_KIT?
          • m5-docsM Offline
            m5-docs @GACHAPO
            @gachapo
            You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
            // Select camera model
            //#define CAMERA_MODEL_WROVER_KIT
            #define CAMERA_A_MODEL_M5STACK_PSRAM
            //#define CAMERA_MODEL_AI_THINKER
            • m5-docsM Offline
              m5-docs
              @GACHAPO @ajb2k3 Thanks your support
              • G Offline
                GACHAPO @m5-docs
                @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
                • m5-docsM Offline
                  m5-docs @GACHAPO
                  @gachapo Do you modify those pin map for adapting to ESP32CAM not M5Camera (A model)?
                  https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L62
                  #elif defined(CAMERA_A_MODEL_M5STACK_PSRAM)
                  #define PWDN_GPIO_NUM     -1
                  #define RESET_GPIO_NUM    15
                  #define XCLK_GPIO_NUM     27
                  #define SIOD_GPIO_NUM     25
                  #define SIOC_GPIO_NUM     23
                  #define Y9_GPIO_NUM       19
                  #define Y8_GPIO_NUM       36
                  #define Y7_GPIO_NUM       18
                  #define Y6_GPIO_NUM       39
                  #define Y5_GPIO_NUM        5
                  #define Y4_GPIO_NUM       34
                  #define Y3_GPIO_NUM       35
                  #define Y2_GPIO_NUM       32
                  #define VSYNC_GPIO_NUM    22
                  #define HREF_GPIO_NUM     26
                  #define PCLK_GPIO_NUM     21
                  • G Offline
                    GACHAPO
                    Yes, as far as I'm aware as long as I have chosen the correct (or in this case closest match) at the top the defined pins should be loaded as below;
                    • m5-docsM Offline
                      m5-docs @GACHAPO
                      @gachapo
                      • G Offline
                        GACHAPO
                        Hello - I've downloaded before but I don't think it has .ino files so can't be used with Arduino.ide. Please advise?
                          ajb2k3 @GACHAPO
                          @gachapo said in [Solved] M5 Burner Firmware Option Update:
                          No, the driver is compiled with the espressiv IDF and so you need to install that and configure it to compile.
                          Something I have failed to do several times now.
                          • m5-docsM Offline
                            m5-docs
                            can also program with arduino ide
                            • G Offline
                              GACHAPO @m5-docs
                              @watson Ok - so frustrated was I with my first attempt I purchased a M5Camera ESP32 PSRAM. Works out of the box nicely, but only on it's own wifi (192.168.4.1). However, as previously I need to get onto my network.
                              Therefore, using Arduino IDE I have gone to File, Examples, ESP32, Camera nd loaded up the sketch from there.
                              I have then amended the SSID and Password to my own and defined the PSRAM camera as below;
                              Compiles and uploaded the sketch.
                              Nothing! - Camera doesn't even turn on.
                              Can somebody please, simply tell me where I am going wrong and how you ever get this great product on your own network.
                              • O Offline
                                Oyye @GACHAPO
                                @gachapo
                                I just registered for you :D
                                Here what is solved my problem (Y2_GPIO_NUM):
                                #elif defined(CAMERA_MODEL_M5STACK_PSRAM)
                                #define Y2_GPIO_NUM 17 //32
                                ajb2k3A G 2 Replies Last reply Reply Quote 0
                                  ajb2k3 @Oyye
                                  @oyye said in [Solved] M5 Burner Firmware Option Update:
                                  @gachapo
                                  Welcome to the forum!
                                  • G Offline
                                    GACHAPO @Oyye
                                    @oyye Thank-you,
                                    I did as you stated with only change from the Arduino Examples being;
                                    This has made no change - Camera still does not come on.
                                    Just to be absolutely clear - this is the camera a have
                                    ![0_1556260445735_20190426_073011.jpg](Uploading 100%)
                                    • G Offline
                                      GACHAPO
                                      Is anybody able to help me please? I now have 2 cameras and I am completely unable to get them on my wifi network as intended. Thank you
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo Do you own M5Camera A model and B model? or ESP32CAM?
                                        • G Offline
                                          GACHAPO @m5-docs
                                          @m5-docs I own an M5 OV2640 ESP32PSRAM Camera
                                          • m5-docsM Offline
                                            m5-docs @GACHAPO
                                            @gachapo But, M5Camera A model and B model both own PSRAM chip.
                                            Please take a picture for your camera board.
                                            https://docs.m5stack.com/#/en/unit/m5camera
