    69 Posts 7 Posters 442.6k Views 1 Watching
    • m5-docsM Offline
      m5-docs @GACHAPO
      @gachapo At main.c file
      M5Stack documentation URL
      https://docs.m5stack.com
      • G Offline
        GACHAPO
        Hi - Can't find main.c file. I've been into the downloaded fiirwares and I can't see it. Where am I going wrong please?
        • m5-docsM Offline
          m5-docs @GACHAPO
          @gachapo
          Download the firmware of ESP32CAM
          • G Offline
            GACHAPO
            ok - so if i amend the main file with my SSID and Password, save and then place the whole directory in the M5 burner directory, refresh the burner, delete the previous firmware on the camera, choose the new firmware and load will that work?
            m5-docsM 2 Replies Last reply Reply Quote 0
              ajb2k3 @m5-docs
              @watson I can't use the M5burner of the Stick C as it it coming up as
              Port: "dev/cu.serial-6D52F9B441
              instead of the expected
              Port: "dev/cu.SLAB_USBtoUART
              • m5-docsM Offline
                m5-docs @ajb2k3
                @ajb2k3 Are you working with Mac OS?
                  ajb2k3 @m5-docs
                  @watson
                  Yes, but is only the StickC that is giving the strange port ID.
                  All others report normal port.
                  • m5-docsM Offline
                    m5-docs @GACHAPO
                    @gachapo I means you can modify main.c file if you want to access other ip address during wifi setting instead of 192.168.4.1. Then compile the camera firmware again and burn it to ESP32CAM
                      salty_good
                      I understood this problem.
                      We need to fix M5Burner for mac.
                        ajb2k3 @salty_good
                        @salty_good said in [updated for Camera boards] M5 Burner Firmware Option Update:
                        Can you add drop down box to select port?
                        ポートを選択するためのドロップダウンボックスを追加できますか?
                        • m5-docsM Offline
                          m5-docs @GACHAPO
                            salty_good @ajb2k3
                            @ajb2k3 Off course yes,
                            and Baudrate also needs to be selectable.
                            • G Offline
                              GACHAPO @m5-docs
                              @watson Thanks - I have amended this. Am I best to use Arduino IDE to compile and upload? Currently when I use Arduino I have several error messages.
                              • m5-docsM Offline
                                m5-docs @GACHAPO
                                Hello @gachapo It's best to use esp-idf.
                                • G Offline
                                  GACHAPO @m5-docs
                                  @watson Thanks- can you use arduino-ide?
                                  • m5-docsM Offline
                                    m5-docs @GACHAPO
                                    Hello @gachapo,
                                    Yes, Color recognition arduino program may help you.
                                    Here's the code:
                                    https://github.com/m5stack/Applications-cam/blob/master/Camera/M5CamColorRecognition/M5CamColorRecognition.ino#L36
                                    • G Offline
                                      GACHAPO @m5-docs
                                      @watson Thank you.
                                      Do I choose CAMERA_MODEL_WROVER_KIT?
                                      • m5-docsM Offline
                                        m5-docs @GACHAPO
                                        @gachapo
                                        You need chang this source code about camera hardware configuration for adapting to ESP32CAM. Because the arduino source code is for M5Camera A model.
                                        // Select camera model
                                        //#define CAMERA_MODEL_WROVER_KIT
                                        #define CAMERA_A_MODEL_M5STACK_PSRAM
                                        //#define CAMERA_MODEL_AI_THINKER
                                        • m5-docsM Offline
                                          m5-docs
                                          @GACHAPO @ajb2k3 Thanks your support
                                          • G Offline
                                            GACHAPO @m5-docs
                                            @watson I have downloaded the M5CamColourRecognition.ino and uploaded to camera successfully. I now have an issued IP address to my network, which I have browsed to and the software loads. However, when I either click get picture or start stream it doesn't work. Please advise?
