    ATOM-DTU-NB-IoT - modem does not respond anymore
    Atom
    6
    27
    29.5k
    • F
      fkarner @felmue
      Hi again @felmue,
      Nice to know that there is no problem caused by this error.
      Contacts facing upward, shape as indicated on the label, should be OK?
      The SIM card does not use a PIN, nevertheless I tried this:
      void nbConnect(void) {
        unsigned long start = millis();
        log("SimStatus: " + String(modem.getSimStatus()));
       if (GSM_PIN && modem.getSimStatus() != 3)
          modem.simUnlock("0000");
      gives this:
      19:20:52.856 -> SimStatus: 0
      19:21:13.040 -> SimStatus: 0
      19:21:13.040 -> Initializing modem...
      So according to this, the SIM card is not ready, right? Could there be a mechanical problem with the SIM card itself?
      flori
      • felmueF
        felmue @fkarner
        Hello @fkarner
        I get SimStatus: 1 when SIM card is installed and recognized. (I get SimStatus: 0 if I remove the SIM card.)
        So yes, it appears that something is either wrong with the SIM card you are using or with the sim card slot in the DTU.
        Thanks
        Felix
        Code examples
        F 1 Reply Last reply Reply Quote 0
        • F
          fkarner @felmue
          Hello @felmue,
          I used your pass-through code example to send the AT+CSMINS? command wich gives this with inserted SIM card:
          20:21:03.854 -> AT+CSMINS?
          20:21:03.854 -> +CSMINS: 0,0
          20:21:03.854 ->
          20:21:03.854 -> OK
          So it seems that the SIM card is not recognized... Maybe broken. Do you have any recommendation for Nb Iot SIM cards? Maybe https://www.miotiq.com/ for Italy?
          Thanks flori
          • felmueF
            felmue @fkarner
            Hello @fkarner
            Miotiq, in my opinion, is a good offer - I tested with one myself. And they list Italy as supported country.
            However, when I tried a while ago, the Miotiq SIM did not allow the modem to connect directly to my server. The modem always has to use the Miotiq backend as a proxy. See here.
            So for instance the M5Stack MQTT example will not work as the modem cannot connect directly to M5Stack MQTT server.
            Thanks
            Felix
            Code examples
            • F
              fkarner @felmue
              Hi @felmue
              @felmue said in ATOM-DTU-NB-IoT - modem does not respond anymore:
              Good to know that. If you hadn't pointed that out, I would have fallen into the next trap.
              So then second best option would be iotcreators? I don't find any information about the need to connect first to a proxy, and the SIMCom7020G is in the list of the certified modems. Should I go for it?
              Thanks flori
              • felmueF
                felmue @fkarner
                Hello @fkarner
                well, while the website iotcreators.com is still up theirs SIM cards no longer seem to be activated. From the iotcreators.com discord server:
                a user asks: "... I'm wondering if iotcreators.com is still active ..." and
                [STAFF] Afzal answers: "It is not. Sorry. I tried my best to keep it alive"
                Thanks
                Felix
                Code examples
                • F
                  fkarner @felmue
                  Hi @felmue
                  Ok, than next option would be simbase.com. They offer Sim Cards also for individuals. Prices seem a bit higher... Covererage is given also for Italy.
                  Anyone has experience with this service?
                  Thanks, flori
