    ATOM-DTU-NB-IoT - modem does not respond anymore
    27 Posts 6 Posters 42.0k Views
      fkarner @felmue
      @felmue said in ATOM-DTU-NB-IoT - modem does not respond anymore:
      hmm, since you already tried changing the modem baudrate I am at a loss what might have gone wrong.
      Hi Felix,
      thank you very much for your answer and the code example. I can upload the code, without errors. The Atom stops here:
      19:19:49.162 -> ets Jun 8 2016 00:22:57
      19:19:49.162 ->
      19:19:49.162 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      19:19:49.162 -> configsip: 188777542, SPIWP:0xee
      19:19:49.162 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      19:19:49.162 -> mode:DIO, clock div:1
      19:19:49.162 -> load:0x3fff0030,len:1344
      19:19:49.162 -> load:0x40078000,len:13964
      19:19:49.162 -> load:0x40080400,len:3600
      19:19:49.162 -> entry 0x400805f0
      19:19:51.594 -> Start SIM7020 passthrough test
      Unfortunately I do not get answer thru the serial monitor... I've tried:
      AT+CEER=?, AT+CGMI=?, AT+CFUN=1. No response... By the way the modem LED's show acitivity red is on, blue flashes with ~.5Hz....
      After that I reinstalled Arduino IDE. Now there are only the M5Stack Boards and the Arduino Boards listed. As Libraries I installed only the M5Unified and the M5GFX. I'm clueless. What could I try next?
      Update: I've tried another 7020G modem. That one answers....
      *19:43:58.890 -> ets Jun 8 2016 00:22:57
      19:43:58.890 ->
      19:43:58.890 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
      19:43:58.922 -> configsip: 188777542, SPIWP:0xee
      19:43:58.922 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      19:43:58.922 -> mode:DIO, clock div:1
      19:43:58.922 -> load:0x3fff0030,len:1344
      19:43:58.922 -> load:0x40078000,len:13964
      19:43:58.922 -> load:0x40080400,len:3600
      19:43:58.922 -> entry 0x400805f0
      19:44:01.378 -> Start SIM7020 passthrough test
      19:44:04.165 -> AT+CEER=?
      19:44:04.197 -> +CEER: (0,1)
      19:44:04.197 ->
      19:44:04.197 -> OK
      19:44:14.518 -> AT+CGMI=?*
      Thanks, flori
        felmue @fkarner
        Hello @fkarner
        thank you for the update. So it's confirmed something's wrong with the first SIM7020G. I still suspect the baudrate got changed somehow, especially since you are writing that the LEDs behave normally.
          fkarner @felmue
          Hi @felmue
          Yes I agree, there must be something wrong with this module. I will investigate that later... First priority is to set up one DTU NB IOT module.
          Unfortunately also with the working modem I get errors using the MQTT code example:
          12:37:55.848 -> Initializing modem...
          12:37:55.848 -> [ 62][E][esp32-hal-gpio.c:102] __pinMode(): Invalid pin selected
          12:37:55.848 -> E (61) gpio: gpio_set_level(227): GPIO output gpio_num error
          12:37:56.138 -> E (364) gpio: gpio_set_level(227): GPIO output gpio_num error
          May they come from the reistallation of Arduino IDE?
          Here are my compiling settings:
          I found the error code here. For sure there must be something wrong with the serial communication.... Strange....
          flori
            felmue @fkarner
            Hello @fkarner
            I get the same error, but it's not fatal. The error stems from the fact that in ATOM_DTU_NB.h a GPIO is defined, e.g.
            #define ATOM_DTU_SIM7020_RESET -1
            for the SIM7020 reset which isn't connected in the DTU.
            If you change that to something like 13 the error goes away.
            The program is probably stuck in Inititalzing modem as it tries to check for the SIM card and that it doesn't have a PIN defined.
            Have you double-checked that the SIM card is placed in the correct orientation and that it doesn't use a PIN?
              fkarner @felmue
              Hi again @felmue,
              Nice to know that there is no problem caused by this error.
              Contacts facing upward, shape as indicated on the label, should be OK?
              The SIM card does not use a PIN, nevertheless I tried this:
              void nbConnect(void) {
                unsigned long start = millis();
                log("SimStatus: " + String(modem.getSimStatus()));
               if (GSM_PIN && modem.getSimStatus() != 3)
                  modem.simUnlock("0000");
              gives this:
              19:20:52.856 -> SimStatus: 0
              19:21:13.040 -> SimStatus: 0
              19:21:13.040 -> Initializing modem...
              So according to this, the SIM card is not ready, right? Could there be a mechanical problem with the SIM card itself?
              flori
                felmue @fkarner
                Hello @fkarner
                I get SimStatus: 1 when SIM card is installed and recognized. (I get SimStatus: 0 if I remove the SIM card.)
                So yes, it appears that something is either wrong with the SIM card you are using or with the sim card slot in the DTU.
                  fkarner @felmue
                  Hello @felmue,
                  I used your pass-through code example to send the AT+CSMINS? command wich gives this with inserted SIM card:
                  20:21:03.854 -> AT+CSMINS?
                  20:21:03.854 -> +CSMINS: 0,0
                  20:21:03.854 ->
                  20:21:03.854 -> OK
                  So it seems that the SIM card is not recognized... Maybe broken. Do you have any recommendation for Nb Iot SIM cards? Maybe https://www.miotiq.com/ for Italy?
                  Thanks flori
                    felmue @fkarner
                    Hello @fkarner
                    Miotiq, in my opinion, is a good offer - I tested with one myself. And they list Italy as supported country.
                    However, when I tried a while ago, the Miotiq SIM did not allow the modem to connect directly to my server. The modem always has to use the Miotiq backend as a proxy. See here.
                    So for instance the M5Stack MQTT example will not work as the modem cannot connect directly to M5Stack MQTT server.
                      fkarner @felmue
                      Hi @felmue
                      Good to know that. If you hadn't pointed that out, I would have fallen into the next trap.
                      So then second best option would be iotcreators? I don't find any information about the need to connect first to a proxy, and the SIMCom7020G is in the list of the certified modems. Should I go for it?
                      Thanks flori
                        felmue @fkarner
                        Hello @fkarner
                        well, while the website iotcreators.com is still up theirs SIM cards no longer seem to be activated. From the iotcreators.com discord server:
                        a user asks: "... I'm wondering if iotcreators.com is still active ..." and
                        [STAFF] Afzal answers: "It is not. Sorry. I tried my best to keep it alive"
                          fkarner @felmue
                          Hi @felmue
                          Ok, than next option would be simbase.com. They offer Sim Cards also for individuals. Prices seem a bit higher... Covererage is given also for Italy.
                          Anyone has experience with this service?
                          Thanks, flori
