    Ideas, helping M5Stack document stuff...
    PRODUCTS
    9
    29
    121.5k
    • RopR
      Rop @m5-docs
      @watson Excellent!! Stuff is being added!! Could you also add the schematics, 3D, etc. of all the bases, including the FACES base and the FACES keyboards ?
      m5-docsM 1 Reply Last reply Reply Quote 0
      • KabronK
        Kabron @m5-docs
        @watson 在 Ideas, helping M5Stack document stuff... 中说:
        I am adding schematic files
        M5Fire schematic still TopSecret?
        • P
          PlayTheGame
          @watson
          M5Fire schematics?
          Its fine to used the altered pin maps as basis but be aware your leaflets contain errors.
          Fire has an undocumented I2C device on the bus, most probably the power management IC.
          M5Camera really I2C SDA on G22 not G25? Schematics?
          M5Core
          Not up to date, connectors missing
          M BUS
          HPWR?
          m5-docsM 2 Replies Last reply Reply Quote 0
          • m5-docsM
            m5-docs @Rop
            @rop
            OK, i am going to talk with our boss about that. Thanks your support.
            M5Stack documentation URL
            https://docs.m5stack.com
            • m5-docsM
              m5-docs @Kabron
              @kabron
              Hey kabron. Fire is not a topsecret. I consider that there are few different between M5Core Basic, M5Core GRAY, M5Fire and the main board(M5Core WHITE) of M5GO. They are simliar to each other. So we just supply the schematic of M5Core Basic.
              Please read this doc. I updated it just now.
              https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md
              loborisL KabronK 2 Replies Last reply Reply Quote 0
              • m5-docsM
                m5-docs @PlayTheGame
                @playthegame
                Hi
                the GROVE Interface(I2C) of M5Camera is G12 and G13
                The IIC address of MPU9250 is 0x68
                Here's the docs about M5Fire and M5Camera
                M5Fire :
                https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire
                M5Camera:
                https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera
                • m5-docsM
                  @playthegame
                  Device IIC address
                  mpu9250 0x68
                  mpu6050 0x68
                  IP5306 0x75
                  MAG3110 0x0E
                  the arly version of M5Fire was built in MPU6050 + MAGE3110, but we change MPU6050 + MAGE3110 to MPU9250.
                  If your m5fire scan i2c address is 0x68 0x75 0x0e, it means your m5fire maybe is previous version.
                  The iic addrss of new m5fire will be 0x68, 0x75
                  The iic addrss of m5core basic will be 0x75, because it has not own mpu9250
                  • loborisL
                    loboris @m5-docs
                    @kabron
                    If it is not a secret, you should make the schematics of all the boards available. How hard can it be to put them on GitHub or somewhere else. Especially if you want those boards to be used by developers who want to do with them more than just playing with nice boxes.
                    • KabronK
                      Kabron @m5-docs
                      It is better to see once than read 100 times bla-bla-bla
