    Ideas, helping M5Stack document stuff...
    29 Posts 9 Posters 132.5k Views 4 Watching
      ajb2k3 @PlayTheGame
      @playthegame 在 Ideas, helping M5Stack document stuff... 中说:
      The forum is hosted by Alisoft (Alibaba group) in Hangzhou behind the great firewall. So something might trigger the behavior (keywords) intentional or not. The main site is hosted in Singapore and not affected.
      Ahh, The Great Firewall of China, I had forgotten about that.
      • KabronK Offline
        Kabron @m5-docs
        @watson 在 Ideas, helping M5Stack document stuff... 中说:
        Please pay more attention to github and docs.
        Schematics???
          ajb2k3 @m5-docs
          To everyone:
          https://github.com/m5stack
          https://m5stack.github.io/m5-docs/#/en/product_documents
          lots of 404 missing pages.
          • m5-docsM Offline
            m5-docs @ajb2k3
            I am fixing it.
            M5Stack documentation URL
            https://docs.m5stack.com
            • m5-docsM Offline
              m5-docs @Kabron
              @kabron
              I am adding schematic files
              https://github.com/m5stack/M5-Schematic
              Here a catalog
              https://github.com/m5stack/M5RepoCatalog
              RopR KabronK 2 Replies Last reply Reply Quote 0
              • RopR Offline
                Rop @m5-docs
                @watson Excellent!! Stuff is being added!! Could you also add the schematics, 3D, etc. of all the bases, including the FACES base and the FACES keyboards ?
                • KabronK Offline
                  Kabron @m5-docs
                  M5Fire schematic still TopSecret?
                    PlayTheGame
                    @watson
                    M5Fire schematics?
                    Its fine to used the altered pin maps as basis but be aware your leaflets contain errors.
                    Fire has an undocumented I2C device on the bus, most probably the power management IC.
                    M5Camera really I2C SDA on G22 not G25? Schematics?
                    M5Core
                    Not up to date, connectors missing
                    M BUS
                    HPWR?
                    m5-docsM 2 Replies Last reply Reply Quote 0
                    • m5-docsM Offline
                      m5-docs @Rop
                      @rop
                      OK, i am going to talk with our boss about that. Thanks your support.
                      • m5-docsM Offline
                        m5-docs @Kabron
                        @kabron
                        Hey kabron. Fire is not a topsecret. I consider that there are few different between M5Core Basic, M5Core GRAY, M5Fire and the main board(M5Core WHITE) of M5GO. They are simliar to each other. So we just supply the schematic of M5Core Basic.
                        Please read this doc. I updated it just now.
                        https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md
                        loborisL KabronK 2 Replies Last reply Reply Quote 0
                        • m5-docsM Offline
                          m5-docs @PlayTheGame
                          @playthegame
                          Hi
                          the GROVE Interface(I2C) of M5Camera is G12 and G13
                          The IIC address of MPU9250 is 0x68
                          Here's the docs about M5Fire and M5Camera
                          M5Fire :
                          https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire
                          M5Camera:
                          https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera
                          • m5-docsM Offline
                            @playthegame
                            Device IIC address
                            mpu9250 0x68
                            mpu6050 0x68
                            IP5306 0x75
                            MAG3110 0x0E
                            the arly version of M5Fire was built in MPU6050 + MAGE3110, but we change MPU6050 + MAGE3110 to MPU9250.
                            If your m5fire scan i2c address is 0x68 0x75 0x0e, it means your m5fire maybe is previous version.
                            The iic addrss of new m5fire will be 0x68, 0x75
                            The iic addrss of m5core basic will be 0x75, because it has not own mpu9250
                            • loborisL Offline
                              loboris @m5-docs
                              @kabron
                              If it is not a secret, you should make the schematics of all the boards available. How hard can it be to put them on GitHub or somewhere else. Especially if you want those boards to be used by developers who want to do with them more than just playing with nice boxes.
                              • KabronK Offline
                                Kabron @m5-docs
                                It is better to see once than read 100 times bla-bla-bla
