    Ideas, helping M5Stack document stuff...
    29 Posts 9 Posters 132.5k Views 4 Watching
      ajb2k3 @PlayTheGame
      @playthegame
      It happens every so often so I'm guessing that the forum is on an IPv4 server.
        PlayTheGame
        The forum is hosted by Alisoft (Alibaba group) in Hangzhou behind the great firewall. So something might trigger the behavior (keywords) intentional or not. The main site is hosted in Singapore and not affected.
        • m5-docsM Offline
          m5-docs @Kabron
          @kabron Sorry, i am adding schematics for m5stack products.
          M5Stack documentation URL
          https://docs.m5stack.com
          • m5-docsM Offline
            m5-docs
            To everyone:
            Please pay more attention to github and docs.
            https://github.com/m5stack
            https://m5stack.github.io/m5-docs/#/en/product_documents
            KabronK ajb2k3A 2 Replies Last reply Reply Quote 0
              ajb2k3 @PlayTheGame
              @playthegame 在 Ideas, helping M5Stack document stuff... 中说:
              Ahh, The Great Firewall of China, I had forgotten about that.
              • KabronK Offline
                Kabron @m5-docs
                @watson 在 Ideas, helping M5Stack document stuff... 中说:
                Schematics???
                  ajb2k3 @m5-docs
                  To everyone:
                  lots of 404 missing pages.
                  • m5-docsM Offline
                    m5-docs @ajb2k3
                    I am fixing it.
                    • m5-docsM Offline
                      m5-docs @Kabron
                      @kabron
                      I am adding schematic files
                      https://github.com/m5stack/M5-Schematic
                      Here a catalog
                      https://github.com/m5stack/M5RepoCatalog
                      RopR KabronK 2 Replies Last reply Reply Quote 0
                      • RopR Offline
                        Rop @m5-docs
                        @watson Excellent!! Stuff is being added!! Could you also add the schematics, 3D, etc. of all the bases, including the FACES base and the FACES keyboards ?
                        • KabronK Offline
                          Kabron @m5-docs
                          M5Fire schematic still TopSecret?
                            PlayTheGame
                            @watson
                            M5Fire schematics?
                            Its fine to used the altered pin maps as basis but be aware your leaflets contain errors.
                            Fire has an undocumented I2C device on the bus, most probably the power management IC.
                            M5Camera really I2C SDA on G22 not G25? Schematics?
                            M5Core
                            Not up to date, connectors missing
                            M BUS
                            HPWR?
                            m5-docsM 2 Replies Last reply Reply Quote 0
                            • m5-docsM Offline
                              m5-docs @Rop
                              @rop
                              OK, i am going to talk with our boss about that. Thanks your support.
                              • m5-docsM Offline
                                m5-docs @Kabron
                                @kabron
                                Hey kabron. Fire is not a topsecret. I consider that there are few different between M5Core Basic, M5Core GRAY, M5Fire and the main board(M5Core WHITE) of M5GO. They are simliar to each other. So we just supply the schematic of M5Core Basic.
                                Please read this doc. I updated it just now.
                                https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md
                                loborisL KabronK 2 Replies Last reply Reply Quote 0
                                • m5-docsM Offline
                                  m5-docs @PlayTheGame
                                  @playthegame
                                  Hi
                                  the GROVE Interface(I2C) of M5Camera is G12 and G13
                                  The IIC address of MPU9250 is 0x68
                                  Here's the docs about M5Fire and M5Camera
                                  M5Fire :
                                  https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire
                                  M5Camera:
                                  https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera
                                  • m5-docsM Offline
                                    @playthegame
                                    Device IIC address
                                    mpu9250 0x68
                                    mpu6050 0x68
                                    IP5306 0x75
                                    MAG3110 0x0E
                                    the arly version of M5Fire was built in MPU6050 + MAGE3110, but we change MPU6050 + MAGE3110 to MPU9250.
                                    If your m5fire scan i2c address is 0x68 0x75 0x0e, it means your m5fire maybe is previous version.
                                    The iic addrss of new m5fire will be 0x68, 0x75
                                    The iic addrss of m5core basic will be 0x75, because it has not own mpu9250
                                    • loborisL Offline
                                      loboris @m5-docs
                                      @kabron
                                      If it is not a secret, you should make the schematics of all the boards available. How hard can it be to put them on GitHub or somewhere else. Especially if you want those boards to be used by developers who want to do with them more than just playing with nice boxes.
                                      • KabronK Offline
                                        Kabron @m5-docs
                                        It is better to see once than read 100 times bla-bla-bla
