    (SOLVED)Power ATOM Lite
    14 Posts 3 Posters 27.5k Views 1 Watching
      cepics
      tnks
        cepics
        max power consumption?
          cepics
          Can I power Atom from grove and ext pin also?
          • m5stackM Offline
            m5stack @cepics
            @cepics yes , you can use grove or ext pin to supply power for Atom. it max power consumption 1.5W
              cepics
              tnks a lot
                Pepsi
                it is possible via the ext pin for 5 volt or also the ext pin for 3.3 volt? (not using the Grove port)
                • m5stackM Offline
                  @pepsi
                  you can see the sticker , the ext pin provided a 5V input pin. the ext Pin 3.3V only can output.
                  0_1586423495012_c5e3b7ac-f9ee-4e75-9149-d7a3791ec99a-image.png?width=300
                    cepics @m5stack
                    @m5stack We are talking about M5Atom here....
                      Pepsi
                      my question is indeed related to the Atom. the symbols on the sticker for the Atom only hold 3V3 and 5V not no arrow if it is input/output.
                      I'm looking for a project with the Atom to run off a LiPo battery.
                      A step down converter will work longer than a step up converter.
                      I know the M5StickC (i have a few), but i need a more robust power switch. and the stick does not have a breakout option for a switch.
                      • m5stackM Offline
                        m5stack @cepics
                        @cepics ....sorry ...i placed the wrong picture。 but they pin function is same. 5V can input/out put. 3.3V can only output
                        • m5stackM Offline
                          m5stack @Pepsi
                          @pepsi ATOM ext Pins. 5V can input/out put. 3.3V can only output
                            Pepsi
                            thank you.
