    (SOLVED)Power ATOM Lite
    Cores
    23.0k
    • C
      cepics
      Hi, how can I power ATOM Lite?
      • m5stackM
        use a usb cable then connect to the power bank or computer
        • C
          cepics
          tnks
          • C
            cepics
            max power consumption?
            • C
              cepics
              Can I power Atom from grove and ext pin also?
              • m5stackM
                m5stack @cepics
                @cepics yes , you can use grove or ext pin to supply power for Atom. it max power consumption 1.5W
                • C
                  cepics
                  tnks a lot
                  • P
                    Pepsi
                    it is possible via the ext pin for 5 volt or also the ext pin for 3.3 volt? (not using the Grove port)
                    • m5stackM
                      @pepsi
                      you can see the sticker , the ext pin provided a 5V input pin. the ext Pin 3.3V only can output.
                      0_1586423495012_c5e3b7ac-f9ee-4e75-9149-d7a3791ec99a-image.png?width=300
                      • C
                        cepics @m5stack
                        @m5stack We are talking about M5Atom here....
                        • P
                          Pepsi
                          my question is indeed related to the Atom. the symbols on the sticker for the Atom only hold 3V3 and 5V not no arrow if it is input/output.
                          I'm looking for a project with the Atom to run off a LiPo battery.
                          A step down converter will work longer than a step up converter.
                          I know the M5StickC (i have a few), but i need a more robust power switch. and the stick does not have a breakout option for a switch.
                          • m5stackM
                            m5stack @cepics
                            @cepics ....sorry ...i placed the wrong picture。 but they pin function is same. 5V can input/out put. 3.3V can only output
                            • m5stackM
                              m5stack @Pepsi
                              @pepsi ATOM ext Pins. 5V can input/out put. 3.3V can only output
                              • P
                                Pepsi
                                thank you.
