    M5Stack Gray & Batteries...
    Modules
    8.7k
    • K
      Kyklist
      Bought M5Stack Gray. Works fine.
      Wanted more battery so bought Battery 700ma module. Works fine.
      Wanted Grove B & C ports so bought Base26. Kind of big...
      Ordered Module Plus which has Grove B & C and a 500ma battery.
      Do I need to remove Module Battery 700ma to use the Module Plus?
      Should I remove the 500ma battery and use both Module Battery 700ma + Module Plus (with 500ma removed)?
      Cheers,
      Ric
      • m5stackM
        m5stack @Kyklist
        @kyklist You can actually stack them together. However, due to different battery capacity combinations, there will be a certain loss of total capacity due to mutual charging.
        K A 2 Replies Last reply Reply Quote 0
        • K
          Kyklist @m5stack
          @m5stack
          Thank you. I will try it when it arrives.
          • A
            ardo @m5stack
            @m5stack
            I have a similar question,
            Is it ok (safe) to put a plus module between a grey and a faces(I) bottom ?
            • m5stackM
              m5stack @ardo
              @ardo Yes, you could connect they together.
