    UART0 (GPIO1,3) usage for RS485 and possible conflict with CP2104
    Modules
    19.3k
    • arzamanA
      arzaman
      Hi would like to use the COMMU module for RS485 interface in particular using the SP3485 tranceiver on UART 0 so GPIO 1 and 3 (M5 bus pin 13 and 14)
      Checking the M5stack basic core schematic seems same GPIO are used for communication with USB serial dirver CP2104
      Is there any possible conflict case ? can I use freely GPIO 1 & 3 on the bus or there is any constraints due to sharing with CP2104 ??
      thanks for any clarification
      Davide
        I think there was an issue report by another forum member but they fixed it by wiring the unit to the other port.
        arzamanA 1 Reply Last reply Reply Quote 0
        • arzamanA
          arzaman @ajb2k3
          @ajb2k3 Unluckily the use of UART2 is NOT an option in my custom circuit since GPIO 16&17 are already used by another device
          I think this is a "general" m5stack core problem: how can I use GPIO 1&3 routed on the bus if they are already in use by the CP2104 ??
          Especially GPIO3 that is an output od the USB to serial adapter
          two useless bus pin ?
          Davide
            Hmn, that is an issue.
            I wonder if a UART switcher/multiplexer could be of use to you in this case.
            • arzamanA
              arzaman
              also in my mind is an issue ...
              is possibile that 2 GPIO of the UART0 routed on the core bus are not usable at all ??
              Davide
              ajb2k3A 2 Replies Last reply Reply Quote 0
                ajb2k3 @arzaman
                @arzaman GPIO2 is on the bus connector pin 19.
                • arzamanA
                  arzaman @ajb2k3
                  @ajb2k3 I was referring to GPIO 1 & 3 that can't be used...
                    ajb2k3 @arzaman
                    @arzaman said in UART0 (GPIO1,3) usage for RS485 and possible conflict with CP2104:
                    Davide
                    Sorry I missunderstood this comment.
                    • arzamanA
                      arzaman
                      I share m5 support answer on the topic
                      "UART0 is a specifically assigned for log print, it is encapsulated by ESP32 at lower layer. It will print the system log automatically and seems like we users are not permitted to shut it down, so we don’t recommend users to use UART0 as a normal UART series port, it will interrupt you communication. That why we connect it with CP2104."
                      to me it's clear the usage of UART0 ..less cleare why this two GPIO are routed to the M5bus since can't be used
                      I will use UART2 for my custom project with this assignment GPIO34=RX GPIO17=TX
                      Davide
