    [Solved]Black screen error
    Cores
    36.6k
    • D
      DavMartEs
      After trying to load a project into the M5Stack Core something must have gone bad because the screen is black. It doesn’t responds to any button and doesn’t change when plugged to energy source. Only when unplugging it from it the screen makes a quick white flick. Is there any procedure to hard reset it / return to factory settings / force it to come back to life?
        What were you using to program the M5Stack core?
        It's hard to tell what has happened without more information.
        If you uploaded a program without a gui then that could be the issue otherwise you can use M5Burner to reinstall the firmware.
        • D
          DavMartEs @ajb2k3
          @ajb2k3 I was using Arduino IDE. Is there any tutorial out there of how to use the burner to reinstall the firmware?
            ajb2k3 @DavMartEs
            @davmartes did your project have any graphical elements?
            It is very hard to brick an M5stack, if its still present in the Ports menu then its fine.
            just try uploading one of the demos/examples.
            • D
              DavMartEs @ajb2k3
              @ajb2k3 I’ve tried but always get same response: A fatal error ocurred Failed to connect to ESP32 Timed out waiting for packet header
                disconnect the usb lead, remove the base plate, plug back in and see what happens.
                • D
                  DavMartEs @ajb2k3
                  @ajb2k3 same result. I detached the screen part from bottom part, put them back together :(. I also tried to load a code pressing reset with same result
                    ajb2k3 @DavMartEs
                    @davmartes
                    If you are on windows, download this, link text
                    OSX download this https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner_MacOS.zip
                    connect the m5 stack and make sure it appears as a com port. (usbtoslab on osx) and run the file.
                    Sometime the black will hiccup and need a capacitor between rst and gnd.
                    • D
                      DavMartEs @ajb2k3
                      @ajb2k3 I’ve tried but burned program can’t run. It gives a message saying SHORTCUT STOPPED WORKING. I’ve tried tu run it over Windows and Linux and none of the versions ran
                        ajb2k3 @DavMartEs
                        @davmartes That is strange.
                        Have you tried restarting your computer (not the m5stack?)
                        • D
                          DavMartEs @ajb2k3
                          @ajb2k3 yes, several times. I am going to try using a different computer now
                            ajb2k3 @DavMartEs
                            @davmartes Are you using the stock black lead?
                              Hi @DavMartEs Dav I just started a chat with you, you should see a notification message at the top of the screen.
                              • D
                                DavMartEs @ajb2k3
                                @ajb2k3 You mean the black core m4stack? Yes
                                • D
                                  DavMartEs @ajb2k3
                                  @ajb2k3 It is strange, because in the second computer I try I get the same error when I try to install the burn program “shortcut has stopped”
                                    We have had issues with the little black lead that comes with the m5stack core black failing. What is more interesting is the error message. does it pop up when starting the burner or when flashing?
                                    • D
                                      DavMartEs @ajb2k3
                                      I wasn’t using the reset button properly when uploading a sketch. I had the .....____....._____ error in Arduino IDE and black screen in M5Stack. Now problem is solved. Thank you for your help!
