    [Solved]M5StickC firmware
    M5 Stick/StickC
    5
    16
    35.2k
    • world101W
      world101
      I just got my M5StickC on Friday. It’s much smaller than I was expecting. It’s really tiny 😀. However, I powered it on and I don’t see anything on the screen. Holding it up to my ear, I hear faint clicking sounds so it seems like it’s doing something. I figured it would at least come with the UIFlow firmware installed, but I maybe not.
      @watson please update the M5Burner for Mac to include the latest firmware for the M5StickC so I can try to flash it. Thanks!
        salty_good @world101
        @world101 Hi, Thank you for your suggestion.
        We will soon prepare the M5Burner with M5StickC firmware for Mac.
        • world101W
          world101 @salty_good
          @salty_good
          What should I use in the meantime? Arduino IDE? Does any firmware come preinstalled with the $1 for M5StickC version?
            @world101 You can use M5StickC on Arduino IDE, Please search M5StickC library.
            Arduino IDE menu
            [Sketch] → [Include Library] → [Manage Libraries...] → search "m5stickc" → install
            Arduino IDE menu again after installed M5StickC library
            [File] → [Examples] → [M5StickC] → choose a sample as you like
            Have enjoy M5StickC!!
            • world101W
              @salty_good thanks! the examples are working for me.
              • m5stackM
                The stickC should have the factory test code burned for default. Please make sure the hardware doesn't have any problem. If the factory test firmware couldn't ran at all as you said didn't see anything on the screen, thats not normal, please test again and let me know if the factory test code works.
                • world101W
                  world101 @m5stack
                  @m5stack said in M5StickC firmware:
                  The one I received did not have the factory test code on it upon arrival. Maybe mine slipped past quality control somehow. However, I was able to burn the FactoryTest.ino sketch using the Arduino IDE and it works.
                  • m5stackM
                    That's fine then as long as the hardware works. we will mark the mistake. Sorry for the inconvenient.
                    • world101W
                      world101
                      It’s all good. Keep up the great work. I love the m5 products!
                      • arzamanA
                        arzaman
                        I have upgraded via M5burner the FW of my M5Stack C to UIflow V1.2.3
                        Is there any way to roll back and load the origina FW for using with the Arduino IDE ??
                        From M5burner not clear what is the FW for Arduino IDE
                        thanks
                        Davide
                        • world101W
                          world101
                          No need to “roll back.” The M5burner is only for UIFlow IDE. To use it with Arduino, just connect the USB from the m5stickC to your computer and upload any Arduino .ino sketch from the m5stickC examples. Follow the instructions from @salty_good above to load the correct libraries into Arduino before uploading.
                          arzamanA 1 Reply Last reply Reply Quote 1
                          • arzamanA
                            arzaman @world101
                            @world101 thank ,
                            so the same bootloader works for arduino IDE and UIflow ? if so is awesome
                            so what is the "original" FW that is pre-loaded?
                            If I udenrstand well the UIflow V1.2.3 loads on ESP32 micro python so sounds strange to me that once you have loaded the UIFlow FW you can use also with arduino IDE (C++)
                            anyway I will try
                            D.
                            ajb2k3A world101W 2 Replies Last reply Reply Quote 0
                              ajb2k3 @arzaman
                              @arzaman the esp32 has two cores, the firmware runs on one and user programmes run on the other core however, I was sure that Arduino programs wrote over the firmware giving access to both cores.
                              • world101W
                                world101 @arzaman
                                @arzaman said in M5StickC firmware:
                                @world101 thank ,
                                anyway I will try
                                D.
                                No it’s one FW or the other. The original FW should be uiFlow (MicroPython), at least for the recent hardware. The older hardware cores (M5Stack black or grey) shipped with a factory test Arduino sketch. All the newer hardware should ship with the uiFlow firmware.
                                Flashing the hardware with the Arduino IDE will overwrite the uiFlow firmware. To get it back to uiFlow (MicroPython), use m5burner.
                                arzamanA 1 Reply Last reply Reply Quote 2
                                • arzamanA
                                  arzaman @world101
                                  @world101
                                  In my case is exactly the contrary...I got the M5Stick C with arduino bootloader FW and I burn UIflow with M5burner
                                  Now would like to revert to arduino...but no idea how to do and where to get the bootloader
                                  any idea ?
                                  Davide
                                    ajb2k3 @arzaman
                                    @arzaman Just upload an arduino program in the normal way. It will overwrite the UIFlow bootloader and you can continue to use the devices.
