    Disable start-up beep
    Cores
    6
    17
    36.9k
    • world101W
      world101
      Is there a way to disable the start-up beep within the firmware?
        m5er
        Indeed, I'm interested in that too. I find that short sound glitch quite annoying.
          ajb2k3 @m5er
          @m5er said in Disable start-up beep:
          And me makes three.
          • m5-docsM
            m5-docs
            Means disable start-up beep within the uiflow firmware?
            M5Stack documentation URL
            https://docs.m5stack.com
            • world101W
              world101 @m5-docs
              @watson said in Disable start-up beep:
              Yes. I found where the second beep is defined when you press buttons A, B, or C after the first beep. But I would like to disable the first beep as well.
                m5er @world101
                @world101, I just tested that commenting out Speaker.begin(); in M5Stack.cpp seems to get rid of the short glitch at startup. That did the trick for me, let me know if that works for you too.
                Of course that applies only to projects that don't need the speaker at all. :)
                • world101W
                  world101 @m5er
                  @m5er
                  Yeah, I know about that for the Arduino IDE, but I was looking for a solution for uiFlow firmware.
                  • H
                    heybin @world101
                    @world101 Hi,if you can flash firmware, i can provide a version without beep :)
                    • world101W
                      world101
                      @heybin said in Disable start-up beep:
                      I assume the first beep is compiled into the firmware bin file and not a configuration setting in one of the python files. Anyway, yes I can flash firmware, so please send it to me.
                      • H
                        heybin @world101
                        Can you send your email to me by chats
                        • world101W
                          world101 @heybin
                          @heybin
                          I got it flashed and it's working good. No startup beep :-)
                          For anyone else interested in v1.2.0 without the startup beeps...
                          https://www.dropbox.com/s/093qcc7e51ywl4m/nobeep.zip?dl=0
                          Pre-requisite: you must have esptool.py installed on your Mac and the m5stack is connected to a USB port.
                          unzip nobeep.zip
                          cd nobeep
                          esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 erase_flash
                          esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 write_flash -z 0x1000 ./bootloader.bin 0xf000 ./phy_init_data.bin 0x10000 ./MicroPython.bin 0x8000 ./partitions_mpy.bin
                          esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 --before default_reset --after no_reset write_flash -z --flash_freq 40m 0x170000 ./spiffs_image_0x170000.img
                          Reboot the m5stack.
                          To silence the second beep (when choosing Upload, App.List, or Setup) do this:
                          Pre-requisite: you must have ampy installed on your Mac
                          ampy get /flash/boot.py
                          Copy the entire output and create a new file called boot.py. Make the change below to set volume=0 in these three locations of the while loop.
                          # wait 1000 for user choose
                          cnt_down = time.ticks_ms() + 1000
                          while time.ticks_ms() < cnt_down:
                              if buttonA.isPressed():   # M5Cloud upload
                                  speaker.tone(2000, 50, volume=0, timer=False) # Beep
                                  core_start('flow')
                                  break
                              elif buttonB.isPressed(): # APP list
                                  from app_manage import file_choose
                                  file_choose()
                                  core_start('app')
                                  break
                              elif buttonC.isPressed(): # WiFi setting
                                  import wifichoose
                                  wifichoose.start()
                                  break
                          Upload the new file to the m5stack:
                          ampy put boot.py /flash/boot.py
                          Reboot the m5stack.
                          • I
                            iPodLux
                            This is great!!! exactly what I was looking for.
                            Would it be possible to have all new firmwares for both core/stick with and without beeps?!? It is quite annoying especially when prototyping with other people around, too many unnecessary resets and beeps
                            Is there a way to put forward a formal request for no-beeps or options in main menu?
                            • I
                              iPodLux
                              the ampy get /flash/boot.py command doesn't seem to work on my mac.
                              I've tried adding the uart address and bauds but no luck.....
                              any caveat?!
                              ajb2k3A world101W 2 Replies Last reply Reply Quote 0
                                ajb2k3 @iPodLux
                                @ipodlux There seams to be a few issues with mac at the moment, the crews are working on trying to solve them.
                                • world101W
                                  world101 @iPodLux
                                  @ipodlux said in Disable start-up beep:
                                  any caveat?!
                                  Did you install ampy on your Mac? If not, it won’t work. You can find install instructions here: https://learn.adafruit.com/micropython-basics-load-files-and-run-code/install-ampy
                                  Also, I need to double check tomorrow, but starting with uiFlow firmware v1.2.3, I think the M5Stack team already disabled the first startup beep in the firmware.
                                  • I
                                    iPodLux @world101
                                    @world101
                                    Hi I certainly did it, ampy is installed and functional but doesn’t seem to connect to the device.
                                    Thanks for looking into this. Removing all unnecessary beeps from the standard firmware would be great. No-one would buy a car honking at every steering or dashboard switch activation!
                                    • world101W
                                      world101 @iPodLux
                                      @ipodlux
                                      If it's not connecting to the device, what errors do you see? Paste your command line output here and maybe I can help further.
                                      One other custom I did for ampy... I created the file ~/.ampy with these contents:
                                      # Example .ampy file
                                      # Please fill in your own port, baud rate, and delay
                                      AMPY_PORT=/dev/tty.SLAB_USBtoUART
                                      AMPY_BAUD=115200
                                      # Fix for macOS users' "Could not enter raw repl"; try 2.0 and lower from there:
                                      #AMPY_DELAY=0.5
                                      If you create that file, you will not have to pass the port and baud rate options when running the ampy command. This is the standard way to run ampy when you don't have the .ampy file created.
                                      world101$ ampy -p /dev/tty.SLAB_USBtoUART -b 115200 ls
                                      /flash
                                      Also, I was mistaken on the the v1.2.3 firmware with the beeps disabled by default. I just flashed one of my cores with the M5Burner and the beeps are there. I must have been running a custom firmware before.
