<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Disable start-up beep]]></title><description><![CDATA[<p dir="auto">Is there a way to disable the start-up beep within the firmware?</p>
]]></description><link>https://community.m5stack.com/topic/684/disable-start-up-beep</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 02:51:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/684.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Feb 2019 01:47:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Disable start-up beep on Sun, 26 May 2019 12:17:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1498">@ipodlux</a></p>
<p dir="auto">If it's not connecting to the device, what errors do you see?  Paste your command line output here and maybe I can help further.</p>
<p dir="auto">One other custom I did for ampy... I created the file ~/.ampy with these contents:</p>
<pre><code># Example .ampy file
# Please fill in your own port, baud rate, and delay
AMPY_PORT=/dev/tty.SLAB_USBtoUART
AMPY_BAUD=115200
# Fix for macOS users' "Could not enter raw repl"; try 2.0 and lower from there:
#AMPY_DELAY=0.5
<p dir="auto">If you create that file, you will not have to pass the port and baud rate options when running the ampy command. This is the standard way to run ampy when you don't have the .ampy file created.</p>
<pre><code>world101$ ampy -p /dev/tty.SLAB_USBtoUART -b 115200 ls
/flash
<p dir="auto">Also, I was mistaken on the the v1.2.3 firmware with the beeps disabled by default. I just flashed one of my cores with the M5Burner and the beeps are there. I must have been running a custom firmware before.</p>
]]></description><link>https://community.m5stack.com/post/4436</link><guid isPermaLink="true">https://community.m5stack.com/post/4436</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sun, 26 May 2019 12:17:03 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Sat, 25 May 2019 20:42:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a><br />
Hi I certainly did it, ampy is installed and functional but doesn’t seem to connect to the device.<br />
Thanks for looking into this. Removing all unnecessary beeps from the standard firmware would be great. No-one  would buy a car  honking at every steering or dashboard switch activation!</p>
]]></description><link>https://community.m5stack.com/post/4432</link><guid isPermaLink="true">https://community.m5stack.com/post/4432</guid><dc:creator><![CDATA[iPodLux]]></dc:creator><pubDate>Sat, 25 May 2019 20:42:10 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Sat, 25 May 2019 02:06:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1498">@ipodlux</a> said in <a href="/post/4416">Disable start-up beep</a>:</p>
<p dir="auto">the ampy get /flash/boot.py command doesn't seem to work on my mac.</p>
<p dir="auto">I've tried adding the uart address and bauds but no luck.....</p>
<p dir="auto">any caveat?!</p>
<p dir="auto">Did you install ampy on your Mac? If not, it won’t work. You can find install instructions here: <a href="https://learn.adafruit.com/micropython-basics-load-files-and-run-code/install-ampy" target="_blank" rel="noopener noreferrer nofollow ugc">https://learn.adafruit.com/micropython-basics-load-files-and-run-code/install-ampy</a></p>
<p dir="auto">Also, I need to double check tomorrow, but starting with uiFlow firmware v1.2.3, I think the M5Stack team already disabled the first startup beep in the firmware.</p>
]]></description><link>https://community.m5stack.com/post/4428</link><guid isPermaLink="true">https://community.m5stack.com/post/4428</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Sat, 25 May 2019 02:06:07 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Thu, 23 May 2019 16:59:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/1498">@ipodlux</a> There seams to be a few issues with mac at the moment, the crews are working on trying to solve them.</p>
]]></description><link>https://community.m5stack.com/post/4417</link><guid isPermaLink="true">https://community.m5stack.com/post/4417</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 23 May 2019 16:59:27 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Thu, 23 May 2019 16:50:13 GMT]]></title><description><![CDATA[<p dir="auto">the ampy get /flash/boot.py command doesn't seem to work on my mac.</p>
]]></description><link>https://community.m5stack.com/post/4416</link><guid isPermaLink="true">https://community.m5stack.com/post/4416</guid><dc:creator><![CDATA[iPodLux]]></dc:creator><pubDate>Thu, 23 May 2019 16:50:13 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Thu, 23 May 2019 16:49:02 GMT]]></title><description><![CDATA[<p dir="auto">This is great!!! exactly what I was looking for.<br />
Would it be possible to have all new firmwares for both core/stick with and without beeps?!? It is quite annoying especially when prototyping with other people around, too many unnecessary resets and beeps</p>
<p dir="auto">Is there a way to put forward a formal request for no-beeps or options in main menu?</p>
]]></description><link>https://community.m5stack.com/post/4415</link><guid isPermaLink="true">https://community.m5stack.com/post/4415</guid><dc:creator><![CDATA[iPodLux]]></dc:creator><pubDate>Thu, 23 May 2019 16:49:02 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Mon, 25 Feb 2019 20:27:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/480">@heybin</a></p>
<p dir="auto">I got it flashed and it's working good.  No startup beep :-)</p>
<p dir="auto">For anyone else interested in v1.2.0 without the startup beeps...<br />
<a href="https://www.dropbox.com/s/093qcc7e51ywl4m/nobeep.zip?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/093qcc7e51ywl4m/nobeep.zip?dl=0</a></p>
<p dir="auto"><strong>Pre-requisite: you must have <a href="https://github.com/espressif/esptool" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> installed on your Mac and the m5stack is connected to a USB port.</strong></p>
<pre><code>unzip nobeep.zip
cd nobeep
esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 erase_flash
esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 write_flash -z 0x1000 ./bootloader.bin 0xf000 ./phy_init_data.bin 0x10000 ./MicroPython.bin 0x8000 ./partitions_mpy.bin
esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 921600 --before default_reset --after no_reset write_flash -z --flash_freq 40m 0x170000 ./spiffs_image_0x170000.img
<p dir="auto">Reboot the m5stack.</p>
<p dir="auto">To silence the second beep (when choosing Upload, App.List, or Setup) do this:<br />
<strong>Pre-requisite: you must have ampy installed on your Mac</strong></p>
<pre><code>ampy get /flash/boot.py
<p dir="auto">Copy the entire output and create a new file called <a href="http://boot.py" target="_blank" rel="noopener noreferrer nofollow ugc">boot.py</a>. Make the change below to set volume=0 in these three locations of the while loop.</p>
<pre><code># wait 1000 for user choose
cnt_down = time.ticks_ms() + 1000
while time.ticks_ms() &lt; cnt_down:
    if buttonA.isPressed():   # M5Cloud upload
        speaker.tone(2000, 50, volume=0, timer=False) # Beep
        core_start('flow')
        break
    elif buttonB.isPressed(): # APP list
        from app_manage import file_choose
        file_choose()
        core_start('app')
        break
    elif buttonC.isPressed(): # WiFi setting
        import wifichoose
        wifichoose.start()
        break
<p dir="auto">Upload the new file to the m5stack:</p>
<pre><code>ampy put boot.py /flash/boot.py
]]></description><link>https://community.m5stack.com/post/3144</link><guid isPermaLink="true">https://community.m5stack.com/post/3144</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Mon, 25 Feb 2019 20:27:04 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Sun, 24 Feb 2019 07:50:41 GMT]]></title><description><![CDATA[<p dir="auto">Can you send your email to me by chats</p>
]]></description><link>https://community.m5stack.com/post/3134</link><guid isPermaLink="true">https://community.m5stack.com/post/3134</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Sun, 24 Feb 2019 07:50:41 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Fri, 22 Feb 2019 03:14:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/480">@heybin</a> said in <a href="/post/3098">Disable start-up beep</a>:</p>
<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> Hi,if you can flash firmware, i can provide a version without beep :)</p>
<p dir="auto">I assume the first beep is compiled into the firmware bin file and not a configuration setting in one of the python files. Anyway, yes I can flash firmware, so please send it to me.</p>
]]></description><link>https://community.m5stack.com/post/3121</link><guid isPermaLink="true">https://community.m5stack.com/post/3121</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Fri, 22 Feb 2019 03:14:07 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Thu, 21 Feb 2019 03:32:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a> Hi,if you can flash firmware, i can provide a version without beep :)</p>
]]></description><link>https://community.m5stack.com/post/3098</link><guid isPermaLink="true">https://community.m5stack.com/post/3098</guid><dc:creator><![CDATA[heybin]]></dc:creator><pubDate>Thu, 21 Feb 2019 03:32:26 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Wed, 20 Feb 2019 01:12:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/966">@m5er</a><br />
Yeah, I know about that for the Arduino IDE, but I was looking for a solution for uiFlow firmware.</p>
]]></description><link>https://community.m5stack.com/post/3082</link><guid isPermaLink="true">https://community.m5stack.com/post/3082</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Wed, 20 Feb 2019 01:12:57 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Tue, 19 Feb 2019 20:39:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/187">@world101</a>, I just tested that commenting out <code>Speaker.begin();</code> in M5Stack.cpp seems to get rid of the short glitch at startup. That did the trick for me, let me know if that works for you too.</p>
<p dir="auto">Of course that applies only to projects that don't need the speaker at all. :)</p>
]]></description><link>https://community.m5stack.com/post/3080</link><guid isPermaLink="true">https://community.m5stack.com/post/3080</guid><dc:creator><![CDATA[m5er]]></dc:creator><pubDate>Tue, 19 Feb 2019 20:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Tue, 19 Feb 2019 03:44:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/133419">@watson</a> said in <a href="/post/3068">Disable start-up beep</a>:</p>
<p dir="auto">Means disable start-up beep within the uiflow firmware?</p>
<p dir="auto">Yes. I found where the second beep is defined when you press buttons A, B, or C after the first beep. But I would like to disable the first beep as well.</p>
]]></description><link>https://community.m5stack.com/post/3071</link><guid isPermaLink="true">https://community.m5stack.com/post/3071</guid><dc:creator><![CDATA[world101]]></dc:creator><pubDate>Tue, 19 Feb 2019 03:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Tue, 19 Feb 2019 02:20:30 GMT]]></title><description><![CDATA[<p dir="auto">Means disable start-up beep within the uiflow firmware?</p>
]]></description><link>https://community.m5stack.com/post/3068</link><guid isPermaLink="true">https://community.m5stack.com/post/3068</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Tue, 19 Feb 2019 02:20:30 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Mon, 18 Feb 2019 10:17:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://community.m5stack.com/uid/966">@m5er</a> said in <a href="/post/3059">Disable start-up beep</a>:</p>
<p dir="auto">Indeed, I'm interested in that too. I find that short sound glitch quite annoying.</p>
<p dir="auto">And me makes three.</p>
]]></description><link>https://community.m5stack.com/post/3060</link><guid isPermaLink="true">https://community.m5stack.com/post/3060</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 18 Feb 2019 10:17:02 GMT</pubDate></item><item><title><![CDATA[Reply to Disable start-up beep on Mon, 18 Feb 2019 10:11:53 GMT]]></title><description><![CDATA[<p dir="auto">Indeed, I'm interested in that too. I find that short sound glitch quite annoying.</p>
]]></description><link>https://community.m5stack.com/post/3059</link><guid isPermaLink="true">https://community.m5stack.com/post/3059</guid><dc:creator><![CDATA[m5er]]></dc:creator><pubDate>Mon, 18 Feb 2019 10:11:53 GMT</pubDate></item></channel></rss>
