    New user having trouble with "download" mode (Atom Lite S3)
    3 Posts 2 Posters 1.8k Views 1 Watching
      mentholmoose
      Well, I'm stuck at about as basic a point as is possible. Got a new Atom Lite S3. Connected to Windows 10, it appears in Device Manager as USB JTAG/serial debug unit.
      Now I want to flash a firmware with m5burner, but I'm doing it wrong. I hold the reset button, the green LED comes on, I release the button and the LED goes off. Click "burn" --> "get mac failed." Tried different sequences of this and always the same result.
      Any help appreciated!
      • robskiR Offline
        robski @mentholmoose
        @mentholmoose is it detected in M5Burner - do you see comX popup in the corner when device usb is plugged in? are you also logged in to your account in M5Burner - you will have to bind device in to your account at some point
          mentholmoose @robski
          @robski - got it solved, turns out the problem was that i was connecting to usb-c on my laptop, which didn't seem like it should be a problem since the Atom Lite also uses usb-c. But once i changed over to my usb-a port, it's all working fine.
