    Trying to compile Core example from M5Stack github
    Cores
    5
    1.2k
    • teastainT
      teastain
      I am trying to compile the Core Basic example from M5Stack github examples:
      https://github.com/m5stack/M5Stack/blob/master/examples/Basics/Button/Button.ino
      I keep getting this error"
      Arduino/libraries/M5Stack/src/utility/pngle.c:31:10: fatal error: rom/miniz.h: No such file or directory
         31 | #include <rom/miniz.h>
      compilation terminated.
      exit status 1
      Because of this I recently erased my entire Arduino IDE down to the Arduino15 folder and only reinstalled the latest:
      Arduino IDE ver2.3.6 and
      esp32 boards 3.2.0 and
      M5Stack boards 3.2.1
      libraries:
      M5Stack latest ver 0.4.6 and all other required dependancies.
      If...(and this is NOT the answer)...I revert to the old M5Stack boards 2.1.4, it compiles correctly. (and this is NOT the answer).
      I keep my Arduino IDE environment up-to-date, but I have to be carful to not allow the M5Stack boards to update to current.
      This is most tedious.
      What can I do to permanently resolve this, going forward...without downgrading to an old M5Stack boards def like 2.1.4.
      (This effects Core2, btw)
      ?How to install rom/miniz and compile OK?
      Cheers, Terry
      (@felmue do you have any ideas?)
      felmueF H 2 Replies Last reply Reply Quote 0
        felmue @teastain
        Hello @teastain
        I am afraid I cannot help, sorry. I exclusively use Visual Studio Code with PlatformIO / pioarduino (which so far doesn't have this issue).
        Note: Visual Studio Code / PlatformIO doesn't use M5Stack boards and setting up new Cores (M5Stack and others) can sometimes be quite difficult as well.
        • H
          HappyUser @teastain
          @teastain
          Change in pngle.c into include <miniz.h> maybe?
          Regards
          • W
            wavydavy
            You can try replacing the following line in the Sketch:
            #include <M5Stack.h>
            With:
            #include <M5Unified.h>
            That should resolve the compilation error.
            • teastainT
              teastain @wavydavy
              @wavydavy I'll try that!
