    UIFlow digital input interrupt
    13 Posts 10 Posters 27.1k Views 6 Watching
    • B Offline
      birdsong
      50hz triac phase control with zero crossing timing synchronization. 100micro second timing tolerance or better. I ended up porting to Arduino/C++, too many limitations with UIFlow for now, python maybe to slow anyway. UIFlow is a good tool for higher level/basic control.
      • G Offline
        Gaviota
        try an execute block, look at my code below.
        First i defined the two variables "is_running" and "counter".
        In UIFlow i defined pin0 with GPIO26 as input with pull down resistor.!
        Then i defined the event_interrupt(pin) - procedure. I use it for counting impulses at the GPIO26, therefore it is necessary to declare the variables as globals.
        Every second i read in the main loop the value of the counter variable and reset the is_running variable.
        def event_interrupt(pin):
        global is_running, counter
        is_running = True
        counter += 1
        pin0.irq(trigger=machine.Pin.IRQ_RISING, handler=event_interrupt)
          Schubi
          @Gaviota
          hello and thank you for your information.
          Would you be so kind to post the full code?
          It doesn't work for me - i always get a syntax error.
          Thanks in advance,
          Schubi
            Schubi
            @Gaviota
            Hello Gaviota,
            thank you for sharing this information.
            I tried to implement it, but i get an error.
            Would you be so kind to post the whole program?
            Thank you in advance,
            Schubi
              Schubi
              @Gaviota
              hello Gaviota,
              i tried to run your code, but i always get an error.
              Would you be so kind to post the full program so i can find my mistake.
              Thank yo in advance,
              Schubi
              • B Offline
                BT99
                @Gaviota post was helpful to me. Thanks.
                Below is an example of a N/O button interrupt, connected between G26 and GND.
                Counter increments multiple times per button push.
                This shows that software debounce could be necessary in many cases.
                Cheers - BillT
                • L Offline
                  LyleDodge
                  I've created a custom module to avoid the need to use the "Execute" block. It basically gives you a way to set the pin number, trigger, and callback for the IRQ. You will still create your own function using Blockly.
                  1. Create a Variable: example "counter"
                  2. Create a Function:
                    1. Name it what you like, example: "count_pulses"
                    2. Add single step from Variables: change counter by 1
                  3. Init PWM0 with your desired pin, freq, and duty
                  4. Load the attached file under Custom | Open *.m5b file
                  5. Drag "PIN_IRQ" from Custom onto your workspace
                    1. Set the pin number (just an integer, 0 for example)
                    2. Set your trigger "machine.Pin.IRQ_RISING"
                    3. Set the handler to your function from step 2 above "count_pulses"
                  6. Add a label if you want and set the loop event to update a label with the current counter value
                  7. It sounds more complicated than it actually is, check the screenshot
                  Your resulting code should look vaguely like this:
                  from m5stack import *
                  from m5ui import *
                  from uiflow import *
                  import machine
                  setScreenColor(0x222222)
                  counter = None
                  label0 = M5TextBox(146, 187, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                  from numbers import Number
                  def count_pulses():
                    global counter
                    counter = (counter if isinstance(counter, Number) else 0) + 1
                  PWM0 = machine.PWM(26, freq=25000, duty=50, timer=0)
                  pin0.irq(trigger=machine.Pin.IRQ_RISING, handler=count_pulses)
                  while True:
                    label0.setText(str(counter))
                    wait_ms(2)
                  Have fun storming the castle!
                  D 1 Reply Last reply Reply Quote 5
                    Doswiadczalnik @LyleDodge
                    @lyledodge I can’t see attached file. Is there any or it problem with my iPhone?
                    • B Offline
                      bozho @Gaviota
                      Hi @Gaviota.
                      Currently I'm still learning to use UI Flow IDE and I want to crate the same thing- counting pulses and showing them on the screen. Can you send me your Blocky?
                      Thanks,
                      Bozho
                        peolsolutions
                        A digital input interrupt in UIFlow is used to respond instantly to changes in the state of a pin, such as the pressing or releasing of a button. Instead of constantly checking the pin, you set an interrupt on a chosen GPIO with rising, falling, or changing detection. The callback function is triggered by this event, making your program more efficient and responsive to real-time input without using excessive processing power.
                          adamm5 @bozho
                          @bozho did you have any luck. It is clear on Uiflow1 how to detect rising inputs but I don't see this on Uiflow2...or is this is actually what is meant by the 'button press' block on the 'pin button' hardware module?
