    UIFlow digital input interrupt
    UIFlow
    10
    13
    20.4k
    • B
      birdsong
      In UIFlow is it possible to use an interrupt on an input? when I get a sub millisecond low signal on an input I would like to run some code.
      • lukasmaximusL
        When you say sub millisecond I guess you are not going to use a button to interrupt, if so then how do you intend to interrupt from an input
        • B
          birdsong
          50hz triac phase control with zero crossing timing synchronization. 100micro second timing tolerance or better. I ended up porting to Arduino/C++, too many limitations with UIFlow for now, python maybe to slow anyway. UIFlow is a good tool for higher level/basic control.
          • G
            Gaviota
            try an execute block, look at my code below.
            First i defined the two variables "is_running" and "counter".
            In UIFlow i defined pin0 with GPIO26 as input with pull down resistor.!
            Then i defined the event_interrupt(pin) - procedure. I use it for counting impulses at the GPIO26, therefore it is necessary to declare the variables as globals.
            Every second i read in the main loop the value of the counter variable and reset the is_running variable.
            def event_interrupt(pin):
            global is_running, counter
            is_running = True
            counter += 1
            pin0.irq(trigger=machine.Pin.IRQ_RISING, handler=event_interrupt)
              Schubi
              @Gaviota
              hello and thank you for your information.
              Would you be so kind to post the full code?
              It doesn't work for me - i always get a syntax error.
              Thanks in advance,
              Schubi
                Schubi
                @Gaviota
                Hello Gaviota,
                thank you for sharing this information.
                I tried to implement it, but i get an error.
                Would you be so kind to post the whole program?
                Thank you in advance,
                Schubi
                  Schubi
                  @Gaviota
                  hello Gaviota,
                  i tried to run your code, but i always get an error.
                  Would you be so kind to post the full program so i can find my mistake.
                  Thank yo in advance,
                  Schubi
                  • B
                    BT99
                    @Gaviota post was helpful to me. Thanks.
                    Below is an example of a N/O button interrupt, connected between G26 and GND.
                    Counter increments multiple times per button push.
                    This shows that software debounce could be necessary in many cases.
                    Cheers - BillT
                    • L
                      LyleDodge
                      I've created a custom module to avoid the need to use the "Execute" block. It basically gives you a way to set the pin number, trigger, and callback for the IRQ. You will still create your own function using Blockly.
                      1. Create a Variable: example "counter"
                      2. Create a Function:
                        1. Name it what you like, example: "count_pulses"
                        2. Add single step from Variables: change counter by 1
                      3. Init PWM0 with your desired pin, freq, and duty
                      4. Load the attached file under Custom | Open *.m5b file
                      5. Drag "PIN_IRQ" from Custom onto your workspace
                        1. Set the pin number (just an integer, 0 for example)
                        2. Set your trigger "machine.Pin.IRQ_RISING"
                        3. Set the handler to your function from step 2 above "count_pulses"
                      6. Add a label if you want and set the loop event to update a label with the current counter value
                      7. It sounds more complicated than it actually is, check the screenshot
                      Your resulting code should look vaguely like this:
                      from m5stack import *
                      from m5ui import *
                      from uiflow import *
                      import machine
                      setScreenColor(0x222222)
                      counter = None
                      label0 = M5TextBox(146, 187, "Text", lcd.FONT_Default, 0xFFFFFF, rotate=0)
                      from numbers import Number
                      def count_pulses():
                        global counter
                        counter = (counter if isinstance(counter, Number) else 0) + 1
                      PWM0 = machine.PWM(26, freq=25000, duty=50, timer=0)
                      pin0.irq(trigger=machine.Pin.IRQ_RISING, handler=count_pulses)
                      while True:
                        label0.setText(str(counter))
                        wait_ms(2)
                      Have fun storming the castle!
                      D 1 Reply Last reply Reply Quote 5
                      • D
                        Doswiadczalnik @LyleDodge
                        @lyledodge I can’t see attached file. Is there any or it problem with my iPhone?
                        • B
                          bozho @Gaviota
                          Hi @Gaviota.
                          Currently I'm still learning to use UI Flow IDE and I want to crate the same thing- counting pulses and showing them on the screen. Can you send me your Blocky?
                          Thanks,
                          Bozho
                          • P
                            peolsolutions Banned
                            A digital input interrupt in UIFlow is used to respond instantly to changes in the state of a pin, such as the pressing or releasing of a button. Instead of constantly checking the pin, you set an interrupt on a chosen GPIO with rising, falling, or changing detection. The callback function is triggered by this event, making your program more efficient and responsive to real-time input without using excessive processing power.
                            • A
                              adamm5 @bozho
                              @bozho did you have any luck. It is clear on Uiflow1 how to detect rising inputs but I don't see this on Uiflow2...or is this is actually what is meant by the 'button press' block on the 'pin button' hardware module?
