    TAB5 and Stamp Connector
    General
    289
      scroggyg
      I have a TAB5 and a M5STAMP-CatM module, there doesn't seem to be any way to connect the 2 The Stamp fits in the aperture in the case and there are pads on the TAB5 PCB but no pins. So do they connect?
      • J
        JKarriot @scroggyg
        @scroggyg I also have the Tab5 and it says it accepts a Stamp Lorawan Module.
        Does that Stamp LoraWan exist???
        • D
          davidedwar
          @scroggyg said in TAB5 and Stamp Connector:
          Yes, they connect — the M5STAMP-CatM is designed to fit into the TAB5 case and align with the pads on the PCB. You’ll need to solder the module to those pads, as there are no pins provided.
            felmue @davidedwar
            Hi guys
            please find some information and pictures of my M5Tab5 with soldered M5Stamp LTE-M module here.
