<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TAB5 and Stamp Connector]]></title><description><![CDATA[<p dir="auto">I have a TAB5 and a M5STAMP-CatM module, there doesn't seem to be any way to connect the 2 The Stamp fits in the aperture in the case and there are pads on the TAB5 PCB but no pins. So do they connect?</p>
]]></description><link>https://community.m5stack.com/topic/7555/tab5-and-stamp-connector</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 15:09:18 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/7555.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 14 May 2025 15:11:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Wed, 23 Jul 2025 03:59:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jkarriot" aria-label="Profile: JKarriot">@<bdi>JKarriot</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/29584</link><guid isPermaLink="true">https://community.m5stack.com/post/29584</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Wed, 23 Jul 2025 03:59:07 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Mon, 21 Jul 2025 22:58:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jkarriot" aria-label="Profile: JKarriot">@<bdi>JKarriot</bdi></a> ???</p>
]]></description><link>https://community.m5stack.com/post/29559</link><guid isPermaLink="true">https://community.m5stack.com/post/29559</guid><dc:creator><![CDATA[JKarriot]]></dc:creator><pubDate>Mon, 21 Jul 2025 22:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Tue, 08 Jul 2025 10:49:21 GMT]]></title><description><![CDATA[<p dir="auto">You're absolutely right — modifying the setup to control the POWERKEY via GPIO is a smart move. It gives you direct control, which is crucial in both scenarios: resetting the modem when it stops responding to AT commands and waking it up from PSM<a href="https://gulfeshop.com/" target="_blank" rel="noopener noreferrer nofollow ugc">.</a> This kind of manual control adds reliability, especially in unattended or remote deployments. Thanks for pointing that out!</p>
]]></description><link>https://community.m5stack.com/post/29430</link><guid isPermaLink="true">https://community.m5stack.com/post/29430</guid><dc:creator><![CDATA[gulfeshop]]></dc:creator><pubDate>Tue, 08 Jul 2025 10:49:21 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Thu, 12 Jun 2025 10:13:27 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/scroggyg" aria-label="Profile: scroggyg">@<bdi>scroggyg</bdi></a></p>
<p dir="auto">the added 5 V power switch I use to fully turn the modem off when I want to use M5Tab5 without modem (without the need to de-solder it.</p>
<p dir="auto">The other modification to control the POWERKEY of the modem via GPIO (instead of the default auto power on) of the modem is required for two cases:</p>
<li>firstly to restart the modem in case it becomes unresponsive to AT commands and</li>
<li>secondly to get it out of PSM (power save mode).</li>
]]></description><link>https://community.m5stack.com/post/29229</link><guid isPermaLink="true">https://community.m5stack.com/post/29229</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 12 Jun 2025 10:13:27 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Thu, 12 Jun 2025 08:32:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks Guys, I assume the switch is necessary to switch off the module, and save power when running on battery?</p>
]]></description><link>https://community.m5stack.com/post/29228</link><guid isPermaLink="true">https://community.m5stack.com/post/29228</guid><dc:creator><![CDATA[scroggyg]]></dc:creator><pubDate>Thu, 12 Jun 2025 08:32:46 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Thu, 05 Jun 2025 13:51:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">I now have the LTE-M modem fully integrated into M5Tab5 (including proper external antenna). Info <a href="https://www.gwendesign.ch/kb/m5stack/m5tab5/" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/29174</link><guid isPermaLink="true">https://community.m5stack.com/post/29174</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 05 Jun 2025 13:51:27 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Sun, 25 May 2025 17:58:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">please find some information and pictures of my M5Tab5 with soldered M5Stamp LTE-M module <a href="https://www.gwendesign.ch/kb/m5stack/m5tab5/" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.</p>
]]></description><link>https://community.m5stack.com/post/29107</link><guid isPermaLink="true">https://community.m5stack.com/post/29107</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 25 May 2025 17:58:33 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Thu, 22 May 2025 07:56:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scroggyg" aria-label="Profile: scroggyg">@<bdi>scroggyg</bdi></a> said in <a href="/post/29053">TAB5 and Stamp Connector</a>:</p>
<p dir="auto">Yes, they connect — the M5STAMP-CatM is designed to fit into the TAB5 case and align with the pads on the PCB<a href="https://www.esnmetal.com/" target="_blank" rel="noopener noreferrer nofollow ugc">.</a> You’ll need to solder the module to those pads, as there are no pins provided.</p>
]]></description><link>https://community.m5stack.com/post/29087</link><guid isPermaLink="true">https://community.m5stack.com/post/29087</guid><dc:creator><![CDATA[davidedwar]]></dc:creator><pubDate>Thu, 22 May 2025 07:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to TAB5 and Stamp Connector on Fri, 16 May 2025 06:28:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/scroggyg" aria-label="Profile: scroggyg">@<bdi>scroggyg</bdi></a> I also have the Tab5 and it says it accepts a Stamp Lorawan Module.<br />
Does that Stamp LoraWan exist???</p>
]]></description><link>https://community.m5stack.com/post/29059</link><guid isPermaLink="true">https://community.m5stack.com/post/29059</guid><dc:creator><![CDATA[JKarriot]]></dc:creator><pubDate>Fri, 16 May 2025 06:28:17 GMT</pubDate></item></channel></rss>
