    EZ Data dissapered from UIflow2
    M5EZ
    5
    5
    3.6k
    • H
      Handcannon
      Was refreshing my EZdata on few devices over the weekend. went back to check on one to change color of LED and its gone. Not at the bottom of page or in the drop down menu.
      kurikoK 1 Reply Last reply Reply Quote 1
      • kurikoK
        kuriko @Handcannon
        @Handcannon
        EZData is under maintenance and will be offline for a while.
        • N
          nnazar @kuriko
          @kuriko
          Hi, When it will be back ?
          Will EZ Data work in UIFlow 2.2.7 ? Because if not, i might have to redo entire work with UIFlow 1.0.
            ajb2k3 @nnazar
            @nnazar EZData was only designed for testing MQTT services.
            I recommend getting something like the CoreMP135 or the CM4 stack, and building your own private dedicated MQTT server on that.
            • B
              Boomvalt @ajb2k3
              @ajb2k3 The point of EZData is that it stores data in a cloud, making it accessible from anywhere in the world. Also, you can set up an mqtt server on a €30 Pi Nano, a NAS, or pretty much any other computer with a network connection.
