    M5Dial can port a or b be used as a second serial port?
    885
      Shanks 0
      Just started playing with the M5Dial and have it working using the USB as a serial port in Arduino. Is there a way to configure either Port A or B as a second serial port in Arduino?
      robskiR ajb2k3A 2 Replies Last reply Reply Quote 0
      • robskiR
        robski @Shanks 0
        @Shanks-0 software serial?
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
          ajb2k3 @Shanks 0
          @Shanks-0
          Port B is generally a no as one of the pins is normally input only
            Shanks 0 @robski
            @robski I don’t think SoftwareSerial library is available for the M5Dial but I will have a look.
            • robskiR
              robski @Shanks 0
              @Shanks-0 its like with M5Core basic with just one port which pins then can be defined to be uart/I2C/GPIO
                Shanks 0 @robski
                @robski I managed to get it to work on Port B, defined the pins in Arduino and used:
                Serial1.begin(9600, SERIAL_8N1, rX1, tX1);
                Works well.
