    4-20 mA Unit with wemos S2 mini ESP32
    Modules
    2.3k
    • O
      obstbauer
      I want to use the 4-20 mA unit with a wemos S2 mini with ESP32 chip but I am not able to get some data from it.
      I had a look at the github examples and made a program to show the current on a display. Display is working and I can find the unit with an i2c scanner.
      Arduino gives no mistakes during compiling but it doesn`t work. Any ideas ?
      Thank you
      Here is my code:
      #include <Wire.h>
      #include <Arduino.h>
      #include <U8g2lib.h>
      #include "MODULE_4_20MA.h"
      U8G2_SSD1309_128X64_NONAME2_F_HW_I2C u8g2(U8G2_R0,U8X8_PIN_NONE);
      const byte led_gpio = 15;   // LED GPIO 15
      MODULE_4_20MA cr;
        Wire.begin(33, 18);  // SDA pin 33, SCL pin 18
        u8g2.begin();
        pinMode(led_gpio, OUTPUT);
        float current = cr.getCurrentValue(0);
        u8g2.firstPage();
        do {
          u8g2.setFont(u8g2_font_ncenB10_tr);
          u8g2.drawStr(0,20,"Strom:");
          u8g2.setCursor(0, 40);
          u8g2.print(current);
        } while ( u8g2.nextPage() );
        digitalWrite(led_gpio, HIGH);
          delay(1000);
        digitalWrite(led_gpio, LOW);
        delay(1000);
        felmue @obstbauer
        Hello @obstbauer
        I think you might want to call cr.begin() in setup to set stuff like the proper I2C address for the library to use. See here.
        • O
          obstbauer @felmue
          @felmue Hello,
          thank you very much, it works !
          I added
          cr.begin(&Wire, MODULE_4_20MA_ADDR, 33, 18, 100000UL);
          to void setup
          • O
            obstbauer
            it seems that I still have a problem....
            I have a current reading but the value is wrong,
            I get soemthing around 7.2 mA instead of 4 mA.
            I can measure the 4 mA with a multimeter in the circuit and the sensor should send 4 mA, so this is ok, but the M5Stack unit shows 7.2 mA and I don't understand why ? Any ideas ?
            My sensor is passive, I connected 24 V to the 4-20mA unit and all three jumpers are installed
            What is the meaning of the function "getCalCurrent" ? It is neessary for the current measurement ? It is necessary to set a "ref current" ?
            Thank you!
            • robskiR
              robski @obstbauer
              @obstbauer try calibration function based on what you see with multimeter
              M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
              • O
                obstbauer @robski
                @robski thanks for the answer
                so you mean if I measure with multimter 4.0 mA (which is true for the sensor) and the unit shows me 7.2 mA I should set the calibrated value to 4.0 ?
                Because this is not mentioned anywhere in a readme file or manual or in the description of the device, and it is not made in the example file at github
                but I am a beginner....
                • robskiR
                  robski @obstbauer
                  @obstbauer thats what i did with mine initially, calibrate with known current value
                  • O
                    obstbauer @robski
                    @robski ok I think I found it:
                    thank you I will try tomorrow
                    • robskiR
                      robski @obstbauer
                      @obstbauer yeah thats the registers table, I used Uiflow2 with calibration block but you are using not M5Stack controller I see
                      • O
                        obstbauer @robski
                        @robski what value do you take for "index" in the function
                        void MODULE_4_20MA::setCalCurrent(uint8_t index, uint16_t value)
                        • robskiR
                          robski @obstbauer
                          @obstbauer haven't used index value
                          in uiflow2 ..ain4_20ma_0.set_cal_current(10) to set 10mA
                          ain4_20ma_0.set_cal_current(20) to set 20mA
                          • O
                            obstbauer @robski
                            @robski yes maybe in uiflow2 but the function for the c program asks for an index and a value
                            • O
                              obstbauer @obstbauer
                              I see really strange behaviour and I don't know the reason and I get no answers from the support.....
                              The example code from M5Stack say that the currentvalue should be divided by 100:
                              canvas.printf("Current:%.2fmA", (float)(meter.getCurrentValue(0)) / 100.0);
                              The values I get I have to divide by 10 to get the right current in mA.... and the other issue is that I can only use half of the measurement range, at 12.5 mA the ADC sends 65520...
                              maybe someone has an idea ?
                              • O
                                change to a raspberry PI4 seems to be no solution too.....
                                it woud be nice if there would be a better documentation for people who want to use the units outside the m5stack universum....
                                • robskiR
                                  robski @obstbauer
                                  @obstbauer this is uiflow example with raw value and float too
                                  • O
                                    obstbauer
                                    thank you, but I am still not able to read out or to set the cal current
                                    M5Stack support doesn`t answer my mails... and it seems that there is nobody from the company around here, I think I will change to another board with better support
                                    • robskiR
                                      robski @obstbauer
                                      @obstbauer TBH if you are using M5Stack modules/units with not M5Stack controllers maybe its worth to have at least one M5Controller (atom?stick? )to be able to check module functionality
