    M5Stack Basic Core Kit v2.7 charging
    8 Posts 3 Posters 5.0k Views
      ChuckInDallas
      Greetings from Dallas.
      New guy here, not understanding how to charge internal battery. I do not have battery base because the use case is for just a small handheld device w/ 1 button active in a physically demanding activity.
      But I am unable to make it do anything if not connected to power source by USB-C.
      1. Does it have internal battery? I think "yes", but how to use it.
      2. If I use one of the "BAT" pins, what volts allowed?
      3. Happy with an answer or specifics of where to find such info in the documentation.
      Thanks,
      Chuck
        felmue @ChuckInDallas
        Hello @ChuckInDallas
        there is a POWER SWITCH at the bottom. See here. Make sure it is in the on position to charge and/or power M5Core.
          ChuckInDallas
          It is in the "On" position. Any other info?
          C.
          • teastainT Offline
            teastain @ChuckInDallas
            @ChuckInDallas Hi!
            The bottom plate (with all the GPIO pins) contains the battery.
            The back should have a switch marked 1/0.
            The switch must be set to 1 and the device powered on by USB.
            The device must be ON during this time, I think, for the battery to charge.
            Until you feel it is charged, then unplug the USB and see if the charge is maintained.
            It only charges this way.
              ChuckInDallas @teastain
              @teastain Thanks. It now does seem to have a battery charge. A little confusing...what is the difference between the "1/0" slide on the bottom and the Red Push Button on the side?
              • teastainT Offline
                @ChuckInDallas The Original Core was found to be wearing out it's battery by applications that were powered by USB 24/7.
                So the new version Core has a switch on the back to isolate the battery from excessive charging by switching it 'out' of the circuit when not needed.
                The red button is the On-Off and reset switch.
                  ChuckInDallas
                  OK. So when on a USB that bottom switch is off unless the user decides to charge the battery?
                  • teastainT Offline
                    @ChuckInDallas Yes.
