    195 Posts 79 Posters 551.0k Views 13 Watching
    • X Offline
      xs
      Are GoPlus2 module not supported in UiFlow2? Do you plan to add support?
      • X Offline
        xs @xs
        @xs Also, Servo2 module isnt sopported
        • ? Offline
          A Former User
          Hello, could you add more RTC blocks to Uiflow2? Like the ones in Uiflow1? I'm a beginner and I wanted to make a simple clock app for the cardputer but for now seems impossible for me without learning to code. Also it would be nice to have all the apps I built in the App.list section of Uiflow2 on my cardputer. Thanks! Screenshot 2024-11-17 194153.png
          cryptospokC 1 Reply Last reply Reply Quote 1
          • cryptospokC Offline
            cryptospok
            I'm using UIFlow2 on Microsoft Edge and when I try to create a variable with the name of an object that already exists, I get the conflict information and even if I correct it, when I exit the variable creation window, UIFlow2 crashes and I have to reload the page to continue.
              cryptospok @Guest
                riztronic
                missing magnetometer scratch code for atom s3r , please add
                kurikoK teastainT 2 Replies Last reply Reply Quote 0
                • kurikoK Offline
                  kuriko @riztronic
                  @riztronic
                  did you mean a built-in magnetometer?
                  • teastainT Offline
                    teastain @riztronic
                    @riztronic The device includes a 5V to 3.3V power circuit, a built-in three-axis BMM150 geomagnetic sensor,
                      Calilov330000
                      Does anyone know how to connect my m5stack core 2 ?
                      Im using the raspberry pi 5. Is the m5stackbcore 2 plug and play with raspberry pi or the websites? Ive neen trying to connect this thing for 2 weeks. This is crazy it takes this much trouble
                      • kurikoK Offline
                        kuriko @Calilov330000
                        @Calilov330000
                        why don't you try a simple laptop/desktop?
                          Davidalan5757
                          Could you unlock from UIFlow 2 the capability to code in micropython…
                            jpilarski
                            I am looking for all of the lcd drawing tools that were available in uiflow1.0. I was making some interactive graphics and I was drawing lines or rectangles in a loop and doing that in uiflow2.0 requires you to first drag out 100 lines in the ui builder which just is too slow. Here are the bloacks I am looking for in uiflow 2.0. How can I do something similar in uiflow 2.0 Screenshot 2025-02-18 235307.png
                              charlesRD
                              I have some difficulties to burn UIFLOW on new devices
                              For ATom lite it seems to work but i get ERROR The device type is unknown! on device manager.
                              I dont know if it can acces to the wifi. i tried several time to unregister and burn it again, reinstall M5 burner, but it doesn't help.
                              It can't connect to my M5 stamp C3, maybe there is a way to make a factory reset on them?
                              The previous Atom and Stick set up in february still worked well, and appears with green dot on device manager. when i try to burn it now i get the "unknown type" error and red dot.
                              it looks like i am not able anymore to have the same atom running when i burn them today.
                              Did i forgot something ?
                              Thank you very much,
                              Charles
                              • Y Offline
                                yaleman
                                  sgu @charlesRD
                                  @charlesRD
                                  i have similar issues
                                  the Tab5 does not burn UIFlow at all!
                                    sgu
                                    When Will LVGL be integrated in UIFlow 2 ? I don't see a progress there for many months. The new devices such as Tab5 are useless without LVGL. Programming with UiFlow 2.0 and printing simple lines and squares look very old school.
                                      hacxx
                                      Thanks for sharing the UiFlow 2.0 resources! I appreciate having a dedicated space for bugs, how-tos, and feature requests. Does anyone have tips on avoiding common firmware burning errors, especially with account binding? Also curious if there’s a timeline for the full API docs release. Looking forward to seeing how this evolves!
                                        thecuri
                                        I recently los all my private cloud projects....is there a way to get them back from your servers?
                                        • Z Offline
                                          zhumingqi
                                          I used UIFlow2 to devleop a simple UI demo, and I monitor the free memory with gc.mem_free(). I found the free memory reduced continiously though I called gc.collect() every loop. Finally, the UI can not update again, but the loop still was running.
                                          Z 1 Reply Last reply Reply Quote 0
                                          • Z Offline
                                            zhumingqi @zhumingqi
                                            I tested more UI design. And I found that the memory leak only happens when I use image component and switch images frequently. Is that a UIFlow2.3.3 bug or my design is incorrect?
