    M5Dial TFT_eSPI pinout
    17 Posts 5 Posters 17.7k Views 1 Watching
      This is the Micropython code I used to get a basic "Hello World" working.
      import os, sys, io
      import M5
      from M5 import *
      label0 = None
      def setup():
        global label0
        M5.begin()
        label0 = Widgets.Label("label", 50, 100, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
        label0.setCursor(x=50, y=100)
        label0.setText(str('Hello World'))
        label0.setVisible(True)
      def loop():
        global label0
        M5.update()
      if __name__ == '__main__':
        try:
          setup()
          while True:
            loop()
          try:
            print_error_msg(e)
          except ImportError:
            print("please update to latest firmware”)
      • gordshG Offline
        gordsh
        @ajb2k3 said in M5Dial TFT_eSPI pinout:
        M5
        Thank you.
          Hello @gordsh
          re TFT_eSPI : try adding the following define in Setup200_GC9A01.h
          #define TFT_BACKLIGHT_ON HIGH
          re GC9A01_demo : please find an M5Dial version here.
          • gordshG Offline
            gordsh
            @felmue, thanks very much, This worked perfectly.
              mukul_100_ @gordsh
              @gordsh Hi ,
              did you get this working ?
              I am banging my head against the wall with this one right now ,
              I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
              also if you have the file of user_setup.h for GC9A01. kindly share
              Thank You
                mukul_100_ @mukul_100_
                @mukul_100_ Got this workking by using m5unified instead of tft_espi
                But i can get the touch to work
                as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
                but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
                gordshG 2 Replies Last reply Reply Quote 0
                • gordshG Offline
                  gordsh @mukul_100_
                  @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
                  • gordshG Offline
                    gordsh @mukul_100_
                    @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
                    M5DialLVGLTouchDemo.ino
                    M gordshG S 3 Replies Last reply Reply Quote 0
                      mukul_100_ @gordsh
                      @gordsh Oh great thanks a lot, I actually got it working,
                      and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                      Also , do you have any idea how the implementation of encoder is eez studio is.
                      i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                      If anyone has any idea or reference, Thank you in advance.
                      also this is the code for how i implemented the button press with encoder
                      // Encoder read function
                      void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                          long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                          if (newPosition != oldPosition) {
                              int encoderDiff = newPosition - oldPosition;
                              oldPosition = newPosition;
                              // React to encoder rotation
                              if (encoderDiff > 0) {
                                  lv_group_focus_next(group);
                              } else if (encoderDiff < 0) {
                                  lv_group_focus_prev(group);
                          // Check button press
                          if (M5Dial.BtnA.wasPressed()) {
                              data->state = LV_INDEV_STATE_PR;
                              Serial.println("M5.BtnA Pressed");
                          } else {
                              data->state = LV_INDEV_STATE_REL;
                      // Display flush function
                      void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                          uint32_t width = (area->x2 - area->x1 + 1);
                          uint32_t height = (area->y2 - area->y1 + 1);
                          M5.Display.startWrite();
                          M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                          M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                          M5.Display.endWrite();
                          lv_disp_flush_ready(disp);
                          auto cfg = M5.config();
                          M5Dial.begin(cfg, true, false);
                          Serial.begin(115200);
                          // LVGL initialization
                          lv_init();
                          lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                          static lv_disp_drv_t disp_drv;
                          lv_disp_drv_init(&disp_drv);
                          disp_drv.hor_res = SCREEN_WIDTH;
                          disp_drv.ver_res = SCREEN_HEIGHT;
                          disp_drv.flush_cb = my_disp_flush;
                          disp_drv.draw_buf = &drawBuffer;
                          lv_disp_drv_register(&disp_drv);
                          static lv_indev_drv_t encoder_drv;
                          lv_indev_drv_init(&encoder_drv);
                          encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                          encoder_drv.read_cb = encoder_read;
                          encoder_indev = lv_indev_drv_register(&encoder_drv);
                          // Create a group and assign it to the encoder input device
                          group = lv_group_create();
                          lv_indev_set_group(encoder_indev, group);
                          // Create focusable widgets
                          lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                          lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                          lv_obj_t *label1 = lv_label_create(btn1);
                          lv_label_set_text(label1, "Button 1");
                          lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                          lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                          lv_obj_t *label2 = lv_label_create(btn2);
                          lv_label_set_text(label2, "Button 2");
                          lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                          lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                          lv_obj_t *label3 = lv_label_create(btn3);
                          lv_label_set_text(label3, "Button 3");
                          // Add widgets to the group
                          lv_group_add_obj(group, btn1);
                          lv_group_add_obj(group, btn2);
                          lv_group_add_obj(group, btn3);
                      • gordshG Offline
                        gordsh @gordsh
                        @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                          mukul_100_ @gordsh
                          @gordsh in your code, is the press function working successfully?
                          i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                            SadE54 @gordsh
                            @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                            gordshG 1 Reply Last reply Reply Quote 0
                            • gordshG Offline
                              gordsh @SadE54
                              @SadE54 I believe it is.
