    M5Dial TFT_eSPI pinout
    17 Posts 5 Posters 17.7k Views 1 Watching
    • gordshG Offline
      gordsh
      @felmue, thanks very much, This worked perfectly.
        mukul_100_ @gordsh
        @gordsh Hi ,
        did you get this working ?
        I am banging my head against the wall with this one right now ,
        I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
        also if you have the file of user_setup.h for GC9A01. kindly share
        Thank You
          mukul_100_ @mukul_100_
          @mukul_100_ Got this workking by using m5unified instead of tft_espi
          But i can get the touch to work
          as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
          but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
          gordshG 2 Replies Last reply Reply Quote 0
          • gordshG Offline
            gordsh @mukul_100_
            @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
            • gordshG Offline
              gordsh @mukul_100_
              @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
              M5DialLVGLTouchDemo.ino
              M gordshG S 3 Replies Last reply Reply Quote 0
                mukul_100_ @gordsh
                @gordsh Oh great thanks a lot, I actually got it working,
                and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                Also , do you have any idea how the implementation of encoder is eez studio is.
                i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                If anyone has any idea or reference, Thank you in advance.
                also this is the code for how i implemented the button press with encoder
                // Encoder read function
                void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                    long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                    if (newPosition != oldPosition) {
                        int encoderDiff = newPosition - oldPosition;
                        oldPosition = newPosition;
                        // React to encoder rotation
                        if (encoderDiff > 0) {
                            lv_group_focus_next(group);
                        } else if (encoderDiff < 0) {
                            lv_group_focus_prev(group);
                    // Check button press
                    if (M5Dial.BtnA.wasPressed()) {
                        data->state = LV_INDEV_STATE_PR;
                        Serial.println("M5.BtnA Pressed");
                    } else {
                        data->state = LV_INDEV_STATE_REL;
                // Display flush function
                void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                    uint32_t width = (area->x2 - area->x1 + 1);
                    uint32_t height = (area->y2 - area->y1 + 1);
                    M5.Display.startWrite();
                    M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                    M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                    M5.Display.endWrite();
                    lv_disp_flush_ready(disp);
                    auto cfg = M5.config();
                    M5Dial.begin(cfg, true, false);
                    Serial.begin(115200);
                    // LVGL initialization
                    lv_init();
                    lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                    static lv_disp_drv_t disp_drv;
                    lv_disp_drv_init(&disp_drv);
                    disp_drv.hor_res = SCREEN_WIDTH;
                    disp_drv.ver_res = SCREEN_HEIGHT;
                    disp_drv.flush_cb = my_disp_flush;
                    disp_drv.draw_buf = &drawBuffer;
                    lv_disp_drv_register(&disp_drv);
                    static lv_indev_drv_t encoder_drv;
                    lv_indev_drv_init(&encoder_drv);
                    encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                    encoder_drv.read_cb = encoder_read;
                    encoder_indev = lv_indev_drv_register(&encoder_drv);
                    // Create a group and assign it to the encoder input device
                    group = lv_group_create();
                    lv_indev_set_group(encoder_indev, group);
                    // Create focusable widgets
                    lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                    lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                    lv_obj_t *label1 = lv_label_create(btn1);
                    lv_label_set_text(label1, "Button 1");
                    lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                    lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                    lv_obj_t *label2 = lv_label_create(btn2);
                    lv_label_set_text(label2, "Button 2");
                    lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                    lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                    lv_obj_t *label3 = lv_label_create(btn3);
                    lv_label_set_text(label3, "Button 3");
                    // Add widgets to the group
                    lv_group_add_obj(group, btn1);
                    lv_group_add_obj(group, btn2);
                    lv_group_add_obj(group, btn3);
                • gordshG Offline
                  gordsh @gordsh
                  @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                    mukul_100_ @gordsh
                    @gordsh in your code, is the press function working successfully?
                    i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                      SadE54 @gordsh
                      @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                      gordshG 1 Reply Last reply Reply Quote 0
                      • gordshG Offline
                        gordsh @SadE54
                        @SadE54 I believe it is.
