    M5Dial TFT_eSPI pinout
    SOFTWARE
    5
    17
    14.0k
    • gordshG
      gordsh
      Does anyone know the correct pin assignment for the M5Dial SPI bus? I am trying to run LVGL with TFT_eSPI. I have tried the pin assignments I obtained from the M5Dial specifications page but I am having no luck. Here is what I have so far
      // For ESP32 Dev board (only tested with GC9A01 display)
      // The hardware SPI can be mapped to any pins
      #define TFT_MOSI 5 // In some display driver board, it might be written as "SDA" and so on.
      #define TFT_SCLK 6
      #define TFT_CS 7 // Chip select control pin
      #define TFT_DC 4 // Data Command control pin
      #define TFT_RST 8 // Reset pin (could connect to Arduino RESET pin)
      #define TFT_BL 9 // LED back-light
        Have you added the GC9A01 driver?
        • gordshG
          gordsh
          @ajb2k3 said in M5Dial TFT_eSPI pinout:
          GC9A01 driver
          Hmm, no I did not. Let me do some research and try to find the driver
          • gordshG
            gordsh
            Can any one get this simple GC9A01 test to run on the M5Dial
            • https://github.com/carlfriess/GC9A01_demo
            My goal is to have LVGL running on the M5Dial so I am working my way through the display issues at this time.
              This is the Micropython code I used to get a basic "Hello World" working.
              import os, sys, io
              import M5
              from M5 import *
              label0 = None
              def setup():
                global label0
                M5.begin()
                label0 = Widgets.Label("label", 50, 100, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                label0.setCursor(x=50, y=100)
                label0.setText(str('Hello World'))
                label0.setVisible(True)
              def loop():
                global label0
                M5.update()
              if __name__ == '__main__':
                try:
                  setup()
                  while True:
                    loop()
                  try:
                    print_error_msg(e)
                  except ImportError:
                    print("please update to latest firmware”)
              • gordshG
                gordsh
                M5
                Thank you.
                  Hello @gordsh
                  re TFT_eSPI : try adding the following define in Setup200_GC9A01.h
                  #define TFT_BACKLIGHT_ON HIGH
                  re GC9A01_demo : please find an M5Dial version here.
                  • gordshG
                    gordsh
                    @felmue, thanks very much, This worked perfectly.
                      mukul_100_ @gordsh
                      @gordsh Hi ,
                      did you get this working ?
                      I am banging my head against the wall with this one right now ,
                      I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
                      also if you have the file of user_setup.h for GC9A01. kindly share
                      Thank You
                        mukul_100_ @mukul_100_
                        @mukul_100_ Got this workking by using m5unified instead of tft_espi
                        But i can get the touch to work
                        as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
                        but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
                        gordshG 2 Replies Last reply Reply Quote 0
                        • gordshG
                          gordsh @mukul_100_
                          @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
                          • gordshG
                            gordsh @mukul_100_
                            @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
                            M5DialLVGLTouchDemo.ino
                            M gordshG S 3 Replies Last reply Reply Quote 0
                              mukul_100_ @gordsh
                              @gordsh Oh great thanks a lot, I actually got it working,
                              and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                              Also , do you have any idea how the implementation of encoder is eez studio is.
                              i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                              If anyone has any idea or reference, Thank you in advance.
                              also this is the code for how i implemented the button press with encoder
                              // Encoder read function
                              void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                                  long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                                  if (newPosition != oldPosition) {
                                      int encoderDiff = newPosition - oldPosition;
                                      oldPosition = newPosition;
                                      // React to encoder rotation
                                      if (encoderDiff > 0) {
                                          lv_group_focus_next(group);
                                      } else if (encoderDiff < 0) {
                                          lv_group_focus_prev(group);
                                  // Check button press
                                  if (M5Dial.BtnA.wasPressed()) {
                                      data->state = LV_INDEV_STATE_PR;
                                      Serial.println("M5.BtnA Pressed");
                                  } else {
                                      data->state = LV_INDEV_STATE_REL;
                              // Display flush function
                              void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                                  uint32_t width = (area->x2 - area->x1 + 1);
                                  uint32_t height = (area->y2 - area->y1 + 1);
                                  M5.Display.startWrite();
                                  M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                                  M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                                  M5.Display.endWrite();
                                  lv_disp_flush_ready(disp);
                                  auto cfg = M5.config();
                                  M5Dial.begin(cfg, true, false);
                                  Serial.begin(115200);
                                  // LVGL initialization
                                  lv_init();
                                  lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                                  static lv_disp_drv_t disp_drv;
                                  lv_disp_drv_init(&disp_drv);
                                  disp_drv.hor_res = SCREEN_WIDTH;
                                  disp_drv.ver_res = SCREEN_HEIGHT;
                                  disp_drv.flush_cb = my_disp_flush;
                                  disp_drv.draw_buf = &drawBuffer;
                                  lv_disp_drv_register(&disp_drv);
                                  static lv_indev_drv_t encoder_drv;
                                  lv_indev_drv_init(&encoder_drv);
                                  encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                                  encoder_drv.read_cb = encoder_read;
                                  encoder_indev = lv_indev_drv_register(&encoder_drv);
                                  // Create a group and assign it to the encoder input device
                                  group = lv_group_create();
                                  lv_indev_set_group(encoder_indev, group);
                                  // Create focusable widgets
                                  lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                                  lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                                  lv_obj_t *label1 = lv_label_create(btn1);
                                  lv_label_set_text(label1, "Button 1");
                                  lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                                  lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                                  lv_obj_t *label2 = lv_label_create(btn2);
                                  lv_label_set_text(label2, "Button 2");
                                  lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                                  lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                                  lv_obj_t *label3 = lv_label_create(btn3);
                                  lv_label_set_text(label3, "Button 3");
                                  // Add widgets to the group
                                  lv_group_add_obj(group, btn1);
                                  lv_group_add_obj(group, btn2);
                                  lv_group_add_obj(group, btn3);
                              • gordshG
                                gordsh @gordsh
                                @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                                  mukul_100_ @gordsh
                                  @gordsh in your code, is the press function working successfully?
                                  i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                                    SadE54 @gordsh
                                    @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                                    gordshG 1 Reply Last reply Reply Quote 0
                                    • gordshG
                                      gordsh @SadE54
                                      @SadE54 I believe it is.
