    ESP32 Arduino vs M5Stack Arduino
    5 Posts 3 Posters 4.5k Views 1 Watching
    • KabronK Offline
      Kabron
      If you are going to define M5 family board in Board Manager, you'll have to choose between two separate variants:
      ESP32 Arduino and M5Stack Arduino.
      See the screenshots.
      These variants are not the same but quite different.
      And compilation results also different.
      As I partially understand the first variant will works with mostly ESP32 libraries,
      while the second one will use M5Stack oriented libraries.
      Are there gurus who can describe in details these differences?
      ajb2k3A teastainT 2 Replies Last reply Reply Quote 0
        ajb2k3 @Kabron
        @Kabron you highlighted m5stampC3 and m5Stack arduino libraries which are two different classes of esp32
        C3 use on die usb adapters, others use external usb adapters
        • teastainT Offline
          teastain @Kabron
          @Kabron, I wish Arduino did not offer M5Stack Boards, when M5Stack official offers up to date board definitions.
          Just use M5Stack!
          I have 'one-of-everything' M5Stack boards and many, many projects later, I'm happy.
          BTW:
          What version of Arduino IDE are you using?
          • KabronK Offline
            Kabron @teastain
            @teastain said in ESP32 Arduino vs M5Stack Arduino:
            Кстати:
            Какую версию Arduino IDE вы используете?
            Does not matter. Same for 2.3.4.
            • teastainT Offline
              teastain @Kabron
              @Kabron It was a friendly 'btw'.
              There is not a bug or a problem.
              It works fine for me on 2.3.4.
              Relax and use the version you prefer.
