    M5StickCPlus2 won’t boot after installing Bruce via Web Updater
    FAQS
    9
    941
    • K
      kaidencoolkid
      When ever I try holding the power button it just shows a green light until I stop holding it. Can I fix it? I’m on a Mac Sequioa and whenever I try to reinstall it it just does the same thing. Also it just says this when I try to use any firmware on the M5Burner. Someone please help me!! It says this “ auto --port /dev/tty.usbserial-586B0029231--baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 8 flash_size detect 0x000 /Applications/M5Burner.app/Contents/Resources/packages/firmware/67e26d43292e054e605d6ec74f8163d
      ode-select: note: No developer tools were found, requesting install.
      developer tools are located at a non-default location on disk, use sudo xcode-select --switch path/to/Xcode.app to specify the Xcode t hat you wish to use for command line developer tools, and cancel the installation dialog.
      See man xcode-select for more details”
      robskiR teastainT 2 Replies Last reply Reply Quote 0
      • robskiR
        robski @kaidencoolkid
        @kaidencoolkid tried to "erase" first? or try to install simple arduino sketch to it. Is com port detected by pc when Stic is connected to usb?
        M5StickC, M5StickCPlus, M5StickCplus2,M5GO, M5Core, M5Tough, M5Core2, M5 Demo Board, M5Dial, M5Paper, M5Atom, M5Cardputer, M5StampS3, CoreMP135, StamPLC, AirQ
        • teastainT
          teastain @kaidencoolkid
          @kaidencoolkid Did you know that Bruce is Hacking software like Nemo and Marauder, a Flipper Zero wannabe?
          Don't install this software.
          • K
            kaidencoolkid @robski
            @robski I’m sort of new can you help me to how to erase it when I try to update it makes like errors or something it can detect the usb it says like “usbmoddem”or something I’m on Mac should I try windows?
            ajb2k3A 2 Replies Last reply Reply Quote 0
              ajb2k3 @kaidencoolkid
              @kaidencoolkid usb modem means not detected
                @kaidencoolkid what device? I have a video on YouTube
                • K
                  kaidencoolkid @ajb2k3
                  @ajb2k3 ohhhhh I did not know that thank you I will try a different one
                  • K
                    @ajb2k3 m5stickcplus2
                      @kaidencoolkid Untill you know how the StickCplus2 works or communicates, only install UIFLow2
