    M5PaperS3 wrong charger -> magic smoke
    Cores
    2.5k
      Hi guys
      even though I read the warning about not using certain types of chargers with M5PaperS3 I managed to do so anyways.
      Suffice to say, M5Paper released some magic smoke and wouldn't start anymore.
      I cracked it open from the back (as I think the eInk display is glued in) to get access to the board. (I do not recommend doing that as it is a destructive process.)
      With the eInk display and touch disconnected I started to inspect the board.
      I found the charger IC USB-C protection diode pack being dead from the look of it. I removed the charger IC (as it is not strictly needed to run) I replaced the USB-C protection diode pack and found the MosFet IC getting pretty hot. So I removed the MosFet as well and injected some voltage (4.2 V) after the MosFet which revealed that the 3.3 V regulator took some hit as well. I replaced the 3.3 V regulator with a similar one I took from an M5Atom.
      With two ICs MosFet removed and the 3.3 V regulator replaced M5PaperS3 took a reasonable small amount of current. I also measured ok voltages for the eInk display so I dared to reattach the display and touch screen and yo and behold - M5PaperS3 is alive again.
      Now I need to order some replacement ICs MosFet.
      You can see the opened M5PaperS3 and the dead ICs here.
      ajb2k3A 1 Reply Last reply Reply Quote 3
        ajb2k3 @felmue
        @felmue thanks for taking the time to write up about it
          felmue @ajb2k3
          Hi guys
          while I am waiting for the replacement on / off MosFet to arrive I was able to put in a temporary fix - I found a similar MosFet in an old, broken MacBook Pro. :-)
          kurikoK 1 Reply Last reply Reply Quote 1
          • kurikoK
            kuriko @felmue
            magic trick!
              felmue @kuriko
              Hi guys
              Update: M5PaperS3 fully restored and as good as new. :-)
