    CoreS3 & NCIR 2 UNIT not reading sensor correctly
    • R
      reptilepvp
      I'm using Arduino IDE 2.3.4 & having the issue with the unit reading the temperature data. If I use UIFLOW the sensor works perfect but whenever I try to get it to read thru IDE. It constantly just reads 2784 degree's. If I use the user demos . It picks up the i2c addy as the default 0x5A. Please help if possible, this is my code .
      #include <M5CoreS3.h>
      #include <M5GFX.h>
      #include <M5UNIT_NCIR2.h>
      #include <M5Unified.h>
      #include <Preferences.h>
      #include <Wire.h>
      // Objects
      M5GFX display;
      M5UNIT_NCIR2 ncir2;
      Preferences preferences;
      int16_t temperature;
      int16_t temperature_soc;
      uint16_t low_alarm_freq, high_alarm_freq, low_alarm_interval,
      high_alarm_interval, buzz_freq;
      uint8_t low_alarm_duty, high_alarm_duty, duty;
      int16_t low_alarm_temp, high_alarm_temp;
      // Global Variables
      float emissivity = 0.95;
      float tempAlert = 30.0;
      int currentPage = 0;
      bool needRedraw = true; // Flag to control screen redraw
      #define M5UNIT_NCIR2_DEFAULT_ADDR 0x5A
      auto cfg = M5.config();
      M5.begin(cfg);
      Serial.begin(115200); // Start serial communication
      ncir2.begin(&Wire,1, 2, M5UNIT_NCIR2_DEFAULT_ADDR);
      // Load settings from preferences
      preferences.begin("settings", true);
      emissivity = preferences.getFloat("emissivity", 0.95);
      tempAlert = preferences.getFloat("tempAlert", 30.0);
      preferences.end();
      M5.Display.fillScreen(TFT_BLACK);
      M5.update();
      // Update the display only if necessary
      if (needRedraw) {
      if (currentPage == 0) {
      drawMainMenu();
      } else if (currentPage == 1) {
      drawSettingsPage();
      needRedraw = false; // Reset redraw flag
      // Handle touch input
      handleMainMenuTouch();
      handleSettingsTouch();
      // Main Menu
      void drawMainMenu() {
      M5.Display.setTextSize(2);
      M5.Display.setCursor(10, 10);
      M5.Display.print("NCIR2 Temp Monitor");
      float temperature = ncir2.getTempValue(); // Now this line will work
      Serial.printf("Temperature Read: %.2f C\n", temperature); // Debug print
      M5.Display.setCursor(10, 50);
      M5.Display.printf("Temp: %.2f C", temperature);
      // Draw Settings button
      M5.Display.fillRect(10, 100, 200, 50, TFT_BLUE);
      M5.Display.setCursor(30, 120);
      M5.Display.setTextColor(TFT_WHITE);
      M5.Display.print("Settings");
      void handleMainMenuTouch() {
      auto detail = M5.Touch.getDetail();
      if (detail.wasPressed()) {
      int x = detail.x;
      int y = detail.y;
      // Check if "Settings" button is pressed
      if (x >= 10 && x <= 210 && y >= 100 && y <= 150) {
        currentPage = 1;  // Navigate to Settings Page
        needRedraw = true; // Set redraw flag
      void drawSettingsPage() {
      M5.Display.printf("Emissivity: %.2f", emissivity);
      M5.Display.setCursor(10, 80);
      M5.Display.printf("Alert Temp: %.2f C", tempAlert);
      // Draw adjustment buttons
      M5.Display.fillRect(10, 120, 80, 50, TFT_GREEN);
      M5.Display.setCursor(20, 140);
      M5.Display.print("Emissivity +");
      M5.Display.fillRect(100, 120, 80, 50, TFT_RED);
      M5.Display.setCursor(110, 140);
      M5.Display.print("Emissivity -");
      M5.Display.fillRect(10, 180, 80, 50, TFT_GREEN);
      M5.Display.setCursor(20, 200);
      M5.Display.print("Temp +");
      M5.Display.fillRect(100, 180, 80, 50, TFT_RED);
      M5.Display.setCursor(110, 200);
      M5.Display.print("Temp -");
      // Draw "Back" button
      M5.Display.fillRect(10, 250, 200, 50, TFT_BLUE);
      M5.Display.setCursor(30, 270);
      M5.Display.print("Back");
      void handleSettingsTouch() {
      int x = detail.x;
      int y = detail.y;
      // Check if "Back" button is pressed
      if (x >= 10 && x <= 210 && y >= 250 && y <= 300) {
        currentPage = 0;  // Navigate back to Main Menu
        return;
      // Check if "+" buttons are pressed to adjust values
      if (x >= 10 && x <= 90 && y >= 120 && y <= 170) {
        emissivity += 0.01;
        saveSettings();
      if (x >= 100 && x <= 180 && y >= 120 && y <= 170) {
        emissivity -= 0.01;
        saveSettings();
      if (x >= 10 && x <= 90 && y >= 180 && y <= 230) {
        tempAlert += 1.0;
        saveSettings();
      if (x >= 100 && x <= 180 && y >= 180 && y <= 230) {
        tempAlert -= 1.0;
        saveSettings();
      void saveSettings() {
      preferences.begin("settings", false);
      preferences.putFloat("emissivity", emissivity);
      preferences.putFloat("tempAlert", tempAlert);
      preferences.end();
      • kurikoK
        kuriko
        @reptilepvp
        I don't quite understand, according to the document, the I2C address of NCIR2 is 0x5A
        Maybe you should try leaving only the code for reading the temperature?
        • R
          reptilepvp @kuriko
          @kuriko i wanted the code to read in Fahrenheit . But also the issue is that it’s the reading the i2c connection but in UIFlow it does.
