    Unable to Authenticate at UIFLOW2 Project Repository
    12 Posts 9 Posters 7.2k Views 1 Watching
      falbriard
      After an update of my password at the M5 Community web site, I lost access to the UIFlow2 project area, not able to authenticate with the new password. The forum access and UIFlow Version1 are working OK. Any hint how to fix it to get access to latest UIFlow2 projects? Thanks for support.
      T R F 3 Replies Last reply Reply Quote 7
        TiukuP @falbriard
        @falbriard Having same issues at the moment. Didn't manage to log in, although password hadn't changed and even after change it didn't work. Gives error "Plese register first".
        1 Reply Last reply Reply Quote 4
          Rango @falbriard
          @falbriard I'm having similar issues. I have not changed my password but I can not log into UIflow2 either. Forum and Uflow1 works.
          Looks like there is an issue with UIflow2 site. I know the recently fixed bugs in 2.1.8 firmware, so site may be down for bug fixes also.
          I plan to keep trying every hour or so.
          1 Reply Last reply Reply Quote 6
            Rango
            Logins to M5Burner also seem to be affected.
            R 1 Reply Last reply Reply Quote 4
              RBOUMAN58 @Rango
              @Rayesyaango
              Yep, that is why i prefer Apps instead of cloud solutions, now weekend so plenty of time just looking at a Core2 and doing ... nothing.
              Can't login can't acces my programms, going to check my tv...
              R 1 Reply Last reply Reply Quote 3
                Rango @RBOUMAN58
                @RBOUMAN58 Totally Agrre. Very dissapointed in M5Stack applications.
                Seems new releases are filled with bugs with no way to access previous working versions. Not to mention being totally locked out today.
                Hey M5Stack Team, any chance on getting an actual app instead of cloud based solution?
                Thank you kindly.
                  heyheyyt
                  it looks like m5stack (uiflow, m5burner...) is experiencing a downtime.
                  I am also getting the same issue.
                  • G Offline
                    gbelfor
                    Ditto. Can't log in. Frustrating indeed.
                      drdrewusaf
                      Same here. Not able to login, no projects load in the Project Zone too.
                        falbriard @falbriard
                        @falbriard said in Unable to Authenticate at UIFLOW2 Project Repository:
                        Its working now, thanks.
                        • kurikoK Online
                          kuriko
                          @drdrewusaf @TiukuP @falbriard @gbelfor @heyheyyt @Rango @RBOUMAN58
                          already fixed, thanks for patience
                            peolsolutions
                            Ensure you're using the correct credentials and that your access permissions are set correctly. Try resetting your password, check if the repository is private, or contact your project administrator for assistance with authentication issues.
