Help: A fatal error occurred: No serial data received.
Hi - I'm new around here, so hello everryone.
I have been getting this error every few times I try to upload and must reconnect the Cardputer (disconnect, press G0 etc.) to get it working again. It happens maybe every 3rd time I want to upload and not only is it becoming very tedious, but I'm worried that it's eventually going to wear out the USB socket.
Does anyone know the solution to this and/or why this happens? I'm using Mac, Arduino IDE 2.3.3. All my libraries are up to date. As I said, it works 2/3 of the time then this happens.
Tried to search - there was a similar query but nobody answered it.
**Sketch uses 666477 bytes (50%) of program storage space. Maximum is 1310720 bytes.
Global variables use 92928 bytes (28%) of dynamic memory, leaving 234752 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port /dev/cu.usbmodem1101
Connecting...
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 48:ca:43:39:2e:60
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600A fatal error occurred: No serial data received.**
