    New M5 AirQ not working?
    6 Posts 4 Posters 4.1k Views
    • G Offline
      gjwep
      Hello, new user here.
      I just received my new M5 AirQ. I have two problems:
      1. AirQ default application not working.
        I followed instructions to connect the device to my access point. It connected but I don't see any data uploaded to the displayed web page and the AirQ display says "Upload... NG: [incrementing number]". The wifi access point does not block the traffic. What could be the problem?
      2. Cannot flash new FW using M5Burner
        Following https://www.youtube.com/watch?v=U6wNe5r8VhA (using a Mac), I don't see a serial port enumerate when I plug in the AirQ, and the Burn attempts fail. The video unfortunately seems to be for Windows users only. Is there a MacOS instruction somewhere?
      Thanks much,
      gj
      ajb2k3A A 2 Replies Last reply Reply Quote 0
        ajb2k3 @gjwep
        @gjwep no communication driver?
        Faulty cable, have put it in boot mode?
        • G Offline
          gjwep @ajb2k3
          @ajb2k3 thanks.
          Is a communication driver required to test the AirQ standalone, just with its demo application on it? This is all done from my iphone as per the instructions. Is there a documentation on the demo application?
          How do I know the device is actually in boot mode?
            ajb2k3 @gjwep
            @gjwep Read the instructions on the website.
              Anasilviaavalos @gjwep
              @gjwep Could you solved this problem?
              I have exactly the same problem, i cant see on the web the information.
              If you did it, could you tell me how you resolved it?
              Thanks u so much
              • robskiR Offline
                robski @Anasilviaavalos
                @Anasilviaavalos had the same, M5burner bind with account and re-load firmware/ user application sorted it
